Question about Philips (142440) Computer Speakers
I have a Philips Freevents X57 Laptop which has a motherboard problem. When I switch the laptop "ON" these are the following symtoms: A) Power Charger in AC/DC Socket without battery: Power LED "ON" B) When switched on the LCD stays blank, the backlight if "OFF" the CPU Fan continuously running. Could someone tell me what might be the problem with the motherboard.
  • GoldHacker May 25, 2011
    Thank you for your reply. I am a qualified technician and I have done the entire standard test and visually inspected the motherboard. My only concern is to fix the motherboard. Do you have the schematic of the motherboard or any experience related these types of faults.
    Brigadier General:
  • 10,406 Answers
Possibilities:
* leaking/bad capacitors on the motherboard, not doing their job, i.e., causing voltage fluctuations that the motherboard cannot tolerate;
* dead disk-drive -- cannot boot Windows from a "dead" drive;
* dead CPU -- cannot do anything other than power on/off;
* failing power-supply -- not supplying correct voltages to the motherboard.
Take the laptop to a qualified computer technician, for professional trouble-shooting, and probably a replacement of the motherboard. But, it might be less expensive to "salvage" the disk-drive (and your files) from the laptop, and to buy a new laptop, than it would be to buy a replacement motherboard, and pay for installation.
Posted on May 20, 2011
  • 1 more comment
  • GoldHacker May 20, 2011
    Thank you for your advice. I need to know which component is faulty on the circuit board
  • ikkenom May 25, 2011
    Replace the CPU, and see if that fixes the problem.
    Replace the RAM, and see if that fixes the problem.
    Replace the power-supply, and see if that fixes the problem.
    Inspect the capacitors on the motherboard, looking for brown "rust" on top of a capacitor, or leaking from the side. Look at the top of each capacitor -- a "good" capacitor will be very "flat", while a "bad" capacitor will be bulging.
  • ikkenom Jun 04, 2011
    >> Do you have the schematic of the motherboard <<
    No, but I have not accessed the web-site of the manufacturer of the computer, to see if they have put a schematics diagram online, as part of a "Technician's Service Manual" for the motherboard.
Remove cd/dvd drive on philips freevents laptop
use a pin on the hole in front of CDROM to open the CD ROM
May 14, 2012 | Philips Brand 12.1 WXGA Glossy Laptop...
I have a Philips Freevents X57 Laptop which has a motherboard problem. When I switch the laptop "ON" these are the following symptoms: A) Power Charger in AC/DC Socket without battery: Power LED...
If you are definitely sure it is not the Power Supply, RAM, CPU, or GPU, then the most likely components are the capacitors or one of the chipsets. More likely one or more of the capacitors has gone bad. However, fixing capacitors, chips, or resistors on a laptop motherboard can be very difficult. I have done some repair work before but not able to do that kind of soldering on something that small.
May 23, 2011 | Philips Computers & Internet
Philips freevents x59 fan does not start causing the laptop to overheat.is there a bios setting for this? If not how do I fix this?
You have to press F2 when you start your laptop. Hope this helps!?
Please rate solution - Thanks
May 15, 2010 | Computers & Internet
Recovery disk for Philips Freevents and system running slow
Readthis thread before you attempt anything.
http://lofi-gaming.org.uk/blog/2008/02/29/how-to-install-xp-on-a-philips-freevents-11nb5800-laptop/
Aug 02, 2009 | Computers & Internet
Over heating laptop - Philips Freevents X51
the overheating of your laptop occurs when there is dust surrounded in the fan. try to open your laptop fan and clean the dust this will surely reduce your over heating problem, thank you,, plz do rate me,,,
Jun 29, 2009 | Fujitsu Siemens Lifebook N5010 Notebook
Philips Freevents X50 charging problems
well my friend I hate to say this but the problem is in the motherboard, and the motherboard should be replaced.
Jun 27, 2009 | Computers & Internet
My sons philips freevents x57 will not boot up. when the power button is pressed the fan whirls for a couple of seconds, the wifi and hdd light blink then nothing even though the power is still on. the...
hi
i think you must do a whole system restore.
because this thing may be because of some changed bios setting..
and if this dont workout...
just put the bootable OS disk in the CD drive and repair the OS.
select the repair option carefully dont select FORMAT option.
if you find the solution helpful dont forget to rate me carefully..
thnx
Jun 25, 2009 | Computers & Internet
Philips Freevents X59 Laptop
Your Freevents X59 came with Intel Video per this download page:
http://support.thetechguys.com/layout.aspx?ID={5471020f-a460-4852-a0f8-5dfb177a91fa}&CatID={aca7f711-30b7-49d9-896c-9ce9537256ef}
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 19, 2008 | Computers & Internet
Laptop screen philips x57 15.4
Take photo from the bottom of your laptop with all words on the bottom and show me again. But could you tell me why you want know the part number if you don't mind?
Nov 12, 2008 | Computers & Internet
have you checked the manufacture website
Jul 28, 2008 | Computers & Internet
Philips (142440) Computer Speakers Logo
254 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
