Have LG 42v5. Suspect YSUS faulty. Output waveform not exactly like service manual. Leds D1 & 2 lit. D17 flashing. D13 lit. D12,11, 10 not lit. Sometimes the screen shows some signs of life (the odd blue pixel lighting up at top of pic). ZSUS waveform looks ok. Control panel & right XSUS have been changed. The original YSUS had blown and I replaced it with a supposedly working one from a dealer. The Y buffers have also been changed. Please help, regards, Mike
5 Suggested Answers
  • 85 Answers
SOURCE: LG 50PX1D, YSUS and ZSUS board replacement
first thing that you can do is use the Google serch by just typing in lg 50px1d and see if you get any thing close to what you need.
Posted on Jan 06, 2009
  • 2318 Answers
SOURCE: Some troubleshooting help please.
The part that caused the fuse to blow is the hybrid that is mounted underneath the heatsink on the YSUS and ZSUS boards. The part used on these boards might be YPPD-J017C or YPPD-J018C, in about 90% of the time, replacing these hybrids fixes the plasmas with no video but good audio. Since VS and GND is shorted, that means that the hybrid has shorted internally. Most service techs would rather replace the entire YSUS or ZSUS boards since the hybrids are very difficult to remove.
Let me know if you require further assistance.
Posted on Apr 09, 2010
Testimonial: "Appreciate the good info and quick reply. THANKS VERY MUCH"
  • 112 Answers
SOURCE: Rebuilding plasma moduel # 6871QYH053B, three
I’m not seeing a direct break down of that 42” Y-Sustain board to see the D1, D7, and D12.\
Look below for the complete diode parts locations, part numbers, and ratings for the 42PC3d-UE.AUSLLJR. That TV has the 6871QYH053B board you asked about.
I hope my information has helped you.
Good Luck.
Posted on May 24, 2010
Testimonial: "Thanks for all the help.I've been in the tv service business for 32 years and it is getting more difficult to get any service information.Thanks again for going out of your way to help. rioconcho"
lovejoy91
  • 691 Answers
SOURCE: the tech said i need a ysus and a zsus board. what
You can check shopjimmy.com or discount-merchant.com or many distrub. sounds like you have no picture.
Posted on Dec 31, 2010
LED tv LG 50LN5200 with no picture but has sound
Faulty the backlight
It is necessary to remove the panel and replace defective LEDs
Best Regards!
Oct 31, 2016 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
Why won't it power up?
Kindly disconnect back light module & try power on , if fail try change any bulged capacitor ,then your VA output should have 5v, 12, & 24v if not present please change your power supply
Jul 19, 2015 | LG 60PS60 60 in. Plasma HDTV
Transmission light flashes after driving a short distance (car just serviced) & "chugs"...turn car off, restart & light goes away (as suggested by mechanic when took car back to him 5
faulty sensor that only puts out faulty waveform when cold,stanadyne electrical shaft sensors in silverado diesel fuel pumps were bad for this
Oct 16, 2014 | 2007 Ford Fiesta 1.4
NOT COMING ON. IS D16 AND D17 NEED REPLACED THERE SMALL AND BLACK .BECAUSE ON ANOTHER BROAD THERES THESE 4 TINY GREEN LIGHTS D15,D16,D17,D18 ONLY D15AND D18 ARE LIGHTING UP
It sounds like a Hitachi--black diodes not the issue--the green ones if Hitachi (how about a model number?) monitor voltages, if they are not lit it means a voltage is not there---look to see if more than 4 green leds and to see if any not lit.
Dec 19, 2012 | Televison & Video
Fisher and Paykel E402B beeping, freezing symbol flashing, crisper bins freezing.
sounds like a sensor faulty will need a tech to recify the problem.
Nov 29, 2012 | Fisher and Paykel Refrigerators
No output on either speakers or headphone, input meters are permanently lit up all the way to the red 0dB LEDs (i.e. overload). I have tried direct USB input and the USB LED on device lights up and...
Ive just fixed 5 of these :D (for a studio)
All had the problem with the signal clip being lit up as soon as you plug it in.
I found on every one, the component U9 had failed! (after 6 hours of probing)thought id post this up as i couldn't find a fix any other place!Checked the service manual, U9 is a:IC VOLTAGE INVERTER CHARGE PUMP UNREG TPS60403 SOT23-5
got mine from:http://int.rsdelivers.com/product/texas-instruments/tps60403dbvt/tps60403-60ma-250khz-inverter-sot23-5/5171208.aspx
soldered it in and jobs a good'n
Jul 17, 2011 | Alesis iO | 2 Sound Card
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
When the LEDs start to flash, release
Continue button. The LEDs will continue flashing until only Error LED will be lit.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
POST is complete when fan noise and rollers stops.
After POST wait for 5 seconds
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
This is the procedure resetting the counter.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
Toner Low LED will be lit.
8. Cycle the power of the printer.
- Remove the power cable
- Wait for 5 seconds
- Plug the power cable back to the printer
- Power the Printer on
Feb 24, 2009 | Dell 1720dn Laser Printer
Auto st-by after 1hour
more likey you need parts lit for this set.It includes YSUS.XSUS and Main power board.I will get back to you on this for part number.You will be amazed on price..
Dec 03, 2007 | Sony PlasmaPro FWD-42PV1A/S 42 in....
TA-N9000ES Amp - Standby light constantly blinks - no sound
The flashing light is indicating that a fault has been detected, and it is staying in "protect mode". First disconnect all cables from the processor (except the power cord) and then power up the processor. This will eliminate the possibility of a shorted cable or a problem with any connected components. f the light still flashes, there is an internal problem and the processor will require profesional service.
Oct 09, 2007 | Sony TA-E9000ES Amplifier
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Electro Med Services...
