Bosch Maxx 5 WAA24162 Washine Machine noisy when its on rinse cycle.
Only 7 hours old my Bosch Maxx 5 very noisy like it wants to fly off especially on the rinse cycle as it starts to vibrate rapidly, when its on its spin cycle slightly noisy but does not vibrate.
I have spent ages leveling the legs where it has got better but still noisy and vibrates.
Can anyone help me?
  • 1 more comment
  • cimeow Aug 14, 2008
    Also i have checked filter, its fine.
    Oh ive just tested it without clothes and its fine.
SOURCE:
  • 641 Answers
SOURCE: Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Posted on Sep 04, 2007
t00nz
  • 4738 Answers
SOURCE: Excessive vibration on spin cycle.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Posted on Sep 18, 2009
beltronic205
  • 1481 Answers
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Posted on Sep 28, 2009
tony2155
  • 64 Answers
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Posted on Mar 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: vibration during the spin cycle
It appears your tub rollers or gliders have failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Bosch maxx 1000 - when finished cycle, leaves central fabric conditioner drawer full of water + trace of condtioner.
Check that the hose that connects the drawer to the tub is clean, fabric conditioner normally gunks up especially on colder wash cycles.
Apr 01, 2015 | Bosch Washing Machines
Bosch maxx 7 varioperfect
On the bottom front there is a panel, that panel is the 'sump' area. Make sure that is cleaned out so that all water can eject during rinse cycle.
Nov 19, 2013 | Washing Machines
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
My 7 year old Bosch dishwasher (SHE56C) started to run for hours when set to wash on any cycle.
Do you hear it go into the drain cycle that is do you hear the drain pump run at some stage. What happens in the rinse program (short cycle)? It is likely the thermostat is not working or the water temperature is too low due to heater problems.
Apr 19, 2013 | Bosch Dishwashers
Our Bosch Maxx 7 skips spin cycle of the washing program. The remaining time jump from about 7 minutes to 2 minutes
Possible that the program controller unit has some errors and so it does work erratically. Check on all connections to the program controller unit, check for moisture on the unit. Also remove power for few hours and see if there is any change.click on : washing machine tips
Mar 14, 2012 | Bosch Washing Machines
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 06, 2011 | Bosch Washing Machines
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 21, 2010 | Washing Machines
Bosch exxcel 1200 express washing machine not working, F63 flashing on display,are the brushes on the motor worn out?
I had F63 on Bosch washing machine (Maxx 7). I waited 5 days for a repairman and all he did was reset the washing machine processor, like this: 1. Turn the program knob to 6 o'clock 2. Hold the RPM button 3. While the RPM button is held, turn the program knob 1 click clockwise (to Rinse) 4. Release the RPM button.
This is similar to F21 which also happened to my machine. Apparently both errors are related to power surge/power cut.
Oct 25, 2010 | Washing Machines
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
