Hello,if the whole oven longer then first see if there is power if it is to supply the fuse, which can be measured volt meter but maybe there will be one more heat than it is to heat that I helped, maybe would help if I could type.
If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
ck wiring ( tec sheet inside the panel - there on most bosch a one time thermo / or it may be a resetable one .but you will have to reset it by pushing the red button . this may correct problem . if it does it again look for a over heating porblem like the ( fan foing too slow. ) or temps prob problems. .. mm / hope this helps / feed back pls /
Hi, most likely to be a faulty element. If the fan is working and there's no heat, definitly is the element. If it tripped the mains, have a good look inside with a torch and should be able to spot either a burn mark, a hole or a bend on the element.
Cheers
hi there sounds like fan oven element at back, don't worry about smoke from grill is more than likley just grease burnning off element, just leave on for a min or two
