Screen display cutting out when u move or ben the screen on its hinges
    Brigadier General:
  • 10,406 Answers
There is a "ribbon" cable between the base (holding the motherboard) and the frame (holding the LCD screen) that transmits the data signals. Obviously, that cable is either partially disconnected, or it is damaged, and "flexing" the laptop triggers the problem.
Take the laptop to a professionial technician, for trouble-shooting and repair.
Posted on May 20, 2011
Laptop hinge wont move
I would loosen or unscrew the 8? screws that hold the display on, this will loosen it off without everything coming apart, then tilt the screen down, lift the from the bottom of the screen, pry without breaking, take that panel off and see if you can replace or find the part that came out, it maybe screws or another piece. You can probably put it back together if it fell out, then just put the screen plate back on.
Aug 23, 2013 | Fujitsu Siemens Computers & Internet
My computer screen won't stay in place
Laptop hinges cannot be tighten. To fix your display hinges, they need to be replaced.
Check out these WEB sites for details on how to replace the hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Jul 22, 2012 | Computers & Internet
How to replace lcd bracket on asus m51sn
Check out these WEB sites for fixing display hinges.Replacing a hinge, or both of them, isn't very tough.
Dec 27, 2011 | ASUS M51SN-A1 LAPTOP LCD SCREEN 15.4" WXGA...
HP Pavilion dv9000 screen lock jamming on the hinge. Is there a key for the nominal padock on the hinge?
I just started getting this problem myself. I'll let you know if I find a solution. For the time being, I'm pinching the joint with my fingers as hard as I can when I open or close it.
Oct 25, 2009 | HP Pavilion dv9000z Notebook
The phone works, recieves and makes calls but both screens are dead???? verizon motorola razr v3
How about the buttons next to the screen? If you do not hear anything when you press those buttons, it is going to be the flex cable. The flex cable connects the phone between the hinge. It connects the 2 displays (it's really one display part with both screens, it has a screen on the front and back).
Basically you have the most common problem with the RAZR, the screen part connects to the bottom via the flex cable and is partially damaged or has ben severed. Not terribly hard to fix but you would need someone who can take it apart and who can get the part as well.
Oct 23, 2009 | Motorola Mobility RAZR V3
THE LID IS LOOSE AND THERE ARE NO SCREWS TO TIGHTEN ON THE HINGES
You do not need to replace the hinges, however your need to remove the font panels of the screen and laptop to remove the hinges. You will see that the pin that connects the top part of the hinge to the bottom part of the hinges has over time moved out of alignment. With pliers and a hammer manipulate the hinge pin so that it is now flush with the hinge itself. You will see that the hinge will then become tight. Then just reinstall the hinge. I just did this and I know it works.
Oct 06, 2009 | Dell Latitude D410 Notebook
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
My nokia 6085 main and mini display went blue and won't show me anything but I can still call people if I remember their number
I had the same problem and mine was 2 months over the year warranty. I took the outer screen casing off and slightly tapped the connector that connects the screen to the keypad. Voila! I had a screen and now I can at least move my info. The top of casing on the screen pops off near the hinge (there should be a notch). Do this gently and lightly move the black connector on the right side as you're facing the hinge. It may buy you a little more time. We'll see how mine does.
Jun 03, 2009 | Nokia 6085 Cellular Phone
Broken Dell Inspiron 1501 Hinge.......?????
Its the LCD backcover assembly that is cracked.
Here is the part number for it: UW737
I found one from somebodys Ebay store (not mine or anybody I know) for less then $30.00.
http://cgi.ebay.com/Dell-Inspiron-1501-LCD-Display-Back-Cover-UW737-%22B%22---Z_W0QQitemZ310140987025QQcmdZViewItemQQimsxZ20090509?IMSfp=TL090509125007r14975
Hope this helps.
Ben
May 29, 2009 | Dell Inspiron 1501 PC Notebook
Retrieving data, broken screen
hi
The Phone needs a new Keypad flex and most likely a left hinge pin. When the phone is open, the cable runs through the left side of the hinge. It is very common for the hinge pin to become chipped and put a small cut in the Flex Cable.
You can get the parts on ebay. search for motorola v3 keypad flex, and motorola v3 hinge, or knuckle.
thankyou.
May 04, 2009 | Cell Phones
Computers & Internet Logo
David Payne
David Payne
