I've got a 2001 BMW 740iL in need of repair/replacement. It's being held together by a couple of pins....and advise is greatly appreciated.
  • 922 Answers
You posted a car question under computer motherboards. Fourtunately, I have a 2000 540i Touring at 115K and can offer some advice.
Your car was not built to be held together with pins. It should be a welded steel unibody with bolts and screws connecting all major mechanical components. If it is held together by pins you would have to be insane to take it out on the road!
What you need to do is to look for BMW-certified technicians in your area and have them examine the car for problems. You are going to have to pay for a couple of hours of shop time but you will get a list of the things that need to be repaired in order based on their threat to your safety.
Then you can attempt the simpler tasks and save up to pay for the big tasks. The most important thing you can do is change the oil every 5000 miles and check under the hood for problems such as leaks and worn hoses regularly.
If you need more information I recommend that you join Bimmerforums.com. I have found it to be an excellent resource for solving problems over the years.
Remember, this is the Ultimate Driving Machine! The cost of owning such a car goes way beyond what you paid for it. For example, my local Mr. Tire cannot align it because it needs a special rack. What sucks is that Mr. Tire did not know that and I went through my new tires in a year! IDIOTS!
Posted on May 20, 2011
Front passenger door won't open on 1995 bmw 740il
what im thinking of doing is putting a lubricant and see if it can help and if that doesnt work might gonna have to change a fuse,relay
Sep 29, 2012 | 1998 BMW 7 Series
I have a 2001 BMW 740IL and would like to change my front struts from EDC to regular struts. Is this possible?
Yes, but you must do all not just fronts. Talk to a couple of tire shops & service centers that do strut work it can get pretty difficult if you don't have tools like spring compressor & air tools.
Apr 04, 2011 | 2001 BMW 7 Series
2001 BMW 740iL is sputtering when I accelarate and shaky when idl
A tune-up and throttle body clean-up is a good idea, but mind you on those cars, the valve covers usually leak into the spark plugs and coils, causing the car to misfire. If you are replacing the plugs and find them soaked in oil; replace your valve cover gaskets or you will be back to the same problem soon after the oil soaks the new plugs back up again.
Jul 22, 2009 | 2006 BMW 750Li
BMW abs light and speedometer not working
I would replace the Vehicle Speed Sensor (VSS) at the transmission 1st, also who advised the PCM (computer) was bad? a Jag dealer? I think they are guessing on that, computers rarely fail, maybe 2% of the time if that.
Jun 25, 2009 | 2001 BMW 5 Series
2001 bmw 740il output speed sensor location
hello ryk786, i/m not a hundred percent certain, but I think the output speed sensor is located at the back of the transmission. With the pan removed, if you look at the valve body and see the EDS valves and connectors, look about 2 inches back toward the end of the case and you should see a connector by itself. There should be a retaining torx bolt and spring holding the sensor in place. After installing the new sensor, do not over-tightend the bolt. The torque should be around 5-6 Nm.
Mar 14, 2009 | 1997 BMW 7 Series
White smoke from the exhaust when I start the car
You have a head gasket leaking or cracked head.
Antifreeze is leaking into the combustion chamber and burning off.
Keep an eye on your coolant level, as it will decrease gradually.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 09, 2009 | 2001 BMW 330
1998 BMW 740IL WILL NOT START
sounds like a battery fault, not holding a charge well
Oct 27, 2008 | 1998 BMW 7 Series
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
