Question about Kenmore Multi-Room Air Conditioner
Why does mine spit water out of the front of the unit when it is on
    Genius:
  • 1,015 Answers
Some things to check are to remove front cover and remove and clean filter if there is one. Check all condensor coils and if they are very dirty remove unit from case by unplugging it and sliding it out. Take it outside and wash it out rhourghly. Clean blower and oil if it has oil ports. Check to see that drain holes on the bottom pan are open and that when you reinstall unit that it is inclined so that condensation can get to drain holes.Check coils after unit has been running for several mins. to see if it is freezing up. If it is then check freon levels and add as needed. Good luck. Thank you
Posted on May 20, 2011
Quie possibly the drain hose is blocked. I assume that this is not a window unit. Therefore, there should be a place on the back or side for drainage. Find that.
Take a wire coat hanger and straighten it out. Carefully, thread the end up inside the drain. Do not force anything. If you run into a full stop, chances are that the drain has a bend in it. The best thing for this is a flexible ,wire wound curtain rod about 1/8" to 3/16" thick. Threading that up the drain should do the trick. That is about all you can do without calling a repairman. Good Luck.
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
I had my unit running in the dehumidifier mode. When I put it in another mode I hear lots of water and it spits water thru the vents. I have a 10,000 btu unit.
You need to tilt it back a little bit. 1/4" per foot. If the unit is 2 feet, from front to back, the back should be 1/2" lower than the front-MINIMUM.
Jun 04, 2011 | Haier Heating & Cooling
My ac is spitting out water in the front and making a loud noise
Your noise is probably your fan hitting water. First try to tilt the ac to slant to the outside. If this is done water should drain to the outside if not your drain hole is blocked from the front to the back you can see this if you remove the unit and look at the front coil housing you will see a very small weep hole clean it out and use a water hose to clean the front coil and the back coil. good luck
Aug 08, 2010 | LG Electronic Window Air Conditioner
It collect in the front of the unit. I put a small
the unit needs to tilt back a little so the condensation can drain also remove front cover and check drain pan is clear of debris so the water can flow back and out of drain
Jul 23, 2010 | LG LB1000ER Air Conditioner
My Lg split system air con spits water
Make sure the unit is tilted downward at the back. About 1" lower than the front is good. Even with a drain, the water will pool inside if it doesn't have a slope for drainage.
Feb 19, 2009 | LG LB1200ER Air Conditioner
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Washing Tabs
Hi Zanussi do not recommend tablets for this machine as it is a jet system and uses far less water than conventional machines. it recommends liquids or loose powder to be used in the tray I know as I sold these for 10 years.
May 04, 2008 | Zanussi ZWF1440 Front Load Washer
Kenmore Multi-Room Air Conditioner Logo
89 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
