Question about Panasonic KXTG6531B Cordless Phone
I CAN NOT GET 1 OF THE HANDSETS OFF OF MUTE - Panasonic KXTG6531B Cordless Phone
    Genius:
  • 1,196 Answers
Try reset that particular hansdset, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Posted on May 20, 2011
Handset display says "Connecting" I can't deregister. How can I get the handset to display "not registered"?
The procedures to deregister are, of course, specific
to each make and model number of cordless phone.
All of them are a LOT more involved than simply
removing the battery.
For some AT&T, VTech, Uniden, & GE model numbers
you might try the following:
For many AT&T models it is simple:
1. When the handset says "Connecting..."
enter *331734 [menu]
it will soon (chirp) and display "Not registered"
For many VTech models it is a bit more involved:
1. Start by taking off the battery compartment cover.
2. press [menu]
3. scroll up/down to "Settings"
4. enter * 7 8 9 0 #
5. if display reads "Test Base",
scroll to "Test Handset", press [select]
scroll to "next page", press [select]
6. scroll to "Register Clear?", press [select]
7. display asks "Confirm?" or "Register Clear??",
press [select]
8. display reads "Ok" (chirps), press [ off ]
9. UNPLUG THE HANDSET BATTERY
(this is why the cover is off)
10. Wait ~30 seconds, re-connect the battery &
replace the cover
11. display reads "Not Registered"
For many Uniden models:
1. Press and hold the [END] and [ # ] keys at the
same time, after a few seconds the display reads
2. "System Reset, Deregister Handset"
3. scroll to "... Base Unavailable"
press [SELECT]
4. Handset (chirps)
press [END]
5. display reads "Not Registered, Place in base..." =====================================
For some GE models:
1. press "program[mute]"
2. scroll to "Handset Setup" press "program[mute]"
3. scroll to "Deregistration" press "program[mute]"
4. scroll to "Yes" press "program[mute]"
5. display reads "Not Registered"
Once you have the handset displaying "Not Registered"
you can follow the User's Manual instructions to register
the handset.
The model number for your cordless phone is shown on
a small sticker underneath the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual if you need it.
Mar 14, 2016 | Lands Phones
Unmute handset
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
Jan 01, 2015 | Uniden Lands Phones
How do I un-mute the handset?
Press the softkey below the "Mute" label. See page 39 of this manual.
Feb 23, 2013 | Panasonic KX-TG2343 Cordless Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
How to mute a vtech 5.8 Ghz Handset Cordless Phone
while the station is ringing ,mute the ringer for this call only.or during a call mute the microphone. hope this helped.
Feb 22, 2011 | Vtech 5.8 Ghz Handset Cordless Phone...
I have a GE model 2810GE AND THE screen say's HAND SET NEEDS REGESTRATION. WHAT SHOULD I DO ? CHARLES
This is from the instructions at GE's site for the model 28110 (you said 2810, which isn't found):
  1. Press the mute/program button. Hold BASE PAGE for 5 seconds, then PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.)
  2. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number
Hope this helps. Thanks for using Fixya!
Feb 11, 2010 | Uniden Cordless Phone
Cannot program, menu stuck on Spanish, cannot access main menu from mute/ok button
I know this should be a MUCH more techie answer, but have you tried just asking a nearby Mexican to help you? Just a thought.....
You say you cannot get to the menu from the mute/ok button?
What happens instead?
FROM DA BOOOK looks pretty clear to me.
Handset Setup
1. Make sure your phone is OFF (not in TALK mode).
2. Press the mute/menu OK button to go to the main menu.
3. Press CALLER ID-VOLUME ( 6 or 5) button to scroll to HANDSET SETUP.
4. Press mute/menu OK button to confirm and you may program the following items: Language, Handset Name, Ringer Tone, Ringer Volume, VIP Melody, Key Tone, Set Day/Time, Equalizer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
NOTE: During programming, you may press the END/cancel button at any time to exit the sub-menu and return to the menu.
Language
From the Handset Setup Menu:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the SET LANGUAGE sub-menu.
2. Press mute/menu OK button to enter the menu. SET LANGUAGE 1ENG 2FRA 3ESP shows in the display.
3. Use the touch tone pad on the handset to select 1ENG, 2FRA, 3ESP, or use the CALLER ID-VOLUME ( 6 or 5) button to scroll to the desired language. English is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the selected language shows in the display.
Apr 29, 2009 | Uniden Cordless Phone
Handset needs registration
I had the same problem and have seemed to figure it out. Take the handset near the base. Press the Prog/Mute button at the bottom of the phone. It will display a message to press the Pager on the base. The phone will then ask you for a Handset Name. Press the Prog/Mute button again and it will name the handset Handset 1.. it is working
Jul 31, 2008 | Uniden Cordless Phone
Cordless phone
push the mute button again should take mute off
Feb 19, 2008 | Panasonic KX-A143E Cordless Expansion...
Panasonic KXTG6531B Cordless Phone Logo
27 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
