Question about Dirt Devil Vacuums
How do I attach the accessory hose to clean down in a couch to my Dirt Devil bagless.
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil Breeze-Bagless Vacuum
You probably have a clog either in the hose , wands, or the dirt inlet by the brush roll.
Posted on Mar 13, 2008
SOURCE: dirt devil en vision
download manual here
http://www.dirtdevil.com/CustomerService/Manuals/
Posted on Jun 24, 2008
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Posted on Jul 30, 2008
SOURCE: DIRT DEVIL CLOGGING IN THE HOSE
What is the solution to this problem ?
Posted on Sep 19, 2008
galati2k
  • 281 Answers
SOURCE: I have a dirt devil featherlite bagless vacuum;
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt travels.is the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
Posted on May 05, 2009
Dirt devil featherlite vaccum were does the extra hose go?
Hi, it's Jeremy from Crucial Vacuum.
Attached is a copy of the user's manual for the Dirt Devil Featherlite Bagless Vacuum M085845. You can find a diagram of your vacuum on page 11 depicting where each part is located. The 2 hoses for your vacuum are listed as numbers 22 and 23.
http://dirtdevil.com/file/898/
You can purchase direct your replacement Dirt Devil parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 04, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How do i use the hose on featherlite bagless
Hello! To use the hose on your Featherlight follow these simple steps below.
· Cleaner must be in its upright position. Remove lower hose from the side of the cleaner by twisting to the right and then pull off.
· Remove the hose from the tool caddy.
· Slide the tool hose into the lower dirt hose with the notch facing up. Push together and twist to secure.
· Choose any of the handy accessories or use the hose alone. Simply push the attachment firmly onto the end of the wand or hose handle. To remove tool, twist and pull apart gently.
I have also included a link to the instruction manual if needed. Hope this was helpful!
http://dirtdevil.com/file/661/
May 17, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Why is my Dirt Devil Vacuum Hose lacking suction?
I have a Dyson and was having a similar problem some time back. I found out these bagless systems still have a filter that picks up the fine dust to keep it contained. Find out where yours is located and beat the dust out of it really good or just replace it.
Hope this helps.
Mar 10, 2014 | Dirt Devil Vacuums
My dirt devil breeze shoots out dirt from vent
try cleaning the filters and clear out hoses, sounds like it has backed up inside, also if the filters aren't clean it can loose suction.
Nov 01, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Hi my dirt devil vision vacuum is having problems. I turn it on and its sounds like its working, but it is not cleaning. Is there a quick fix?
Check there is no blockage in hose. If bagless check filter they clog up quickly I personally dislike bagless vacumns
Dec 18, 2009 | Dirt Devil M088905 Vision Bagless Upright...
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Mar 09, 2009 | Dirt Devil M087700SV Bagless Upright...
Missing dirt devil featherlite bagless attachment accessories
call them back and ask when you can expect your attachments/accessories
Feb 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dynamite Dirt Devil Hose
I figured out how last night.
Take a screw driver and unscrew the screw on the top of hose and take the hose out and take a pen or something long enough with grip to get all of the junk out.
The circulation still isn't as strong though.
Dec 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
DIRT DEVIL VISION BAGLESS UPRIGHT
Check further down, by the brush roll, the inlet may be clogged, or something like a nail or pin wedged sideways in the hose, and catches debris and clogs up. This has a one year warranty, if you still can't firgure it out, take it to a warranty shop and take proof of purchase with you.
Dec 29, 2007 | Dirt Devil Featherlight Bagless Upright...
Vacuums Logo
47 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
