Question about Car Audio & Video
I have a 600 watt lanzar vibe 411 car amp that shuts off when trying play stereo. I was wondering what the problem could be, and how to fix it?
Duncan
  • 218 Answers
SOURCE: my vibe 286 4000 watt lanzar amp wont stay on..
Check your speaker load. It probably should be 4 ohms per channel. Also, if you are bridging then you must double your ohms load. It may be that your old amp could tolerate a lower impedence (ohms load) than the new amp. Do this now so you don't fry your amp. Good luck.
Posted on Mar 05, 2007
  • 5 Answers
SOURCE: 600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Posted on Oct 09, 2007
Cerfer39
  • 709 Answers
SOURCE: 600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Posted on Oct 23, 2007
SOURCE: Protection mode on Lanzar Vibe 241
check to make sure your power cable is hooked up well to the battery. i had this problem twice and this was the solution both times
Posted on Jul 01, 2008
SOURCE: my amp wont go past protect mode
I had the same problem. be sure to change all transistors cause once one goes the rest useally goes right along with it... replaceing one or two transistors will not do the trick, cause once you power up again the rest of them will go, & you will have to repeat the prosses
Posted on Nov 25, 2008
How to connect vibe 210 amp in 2003 pt cruiser
You will need to acquire a vehicle-specific car stereo adapter harness. Best source is eBay or Amazon.
May 12, 2015 | Sound Around Lanzar Vibe2102n Vibe 6000...
Amp wont play
Quick test...with your Lanzar volume all the way down, connect MP3 player or other type audio source directly to the subwoofer input connection. Play audio and slowly increase volume control. If subwoofer is working using this method, reconnect and check for audio output to Lanzer connection problem, or subwoofer "settings" issues with the receiver.
Nov 11, 2013 | Lanzar VCTBS8 Vector 8-Inch Super-Slim...
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
Amp blows fuses
Are you using the correct fuse? if so,
more then likely, you don't have a good ground. Try grounding to something else that has more direct connection to your frame. If that doesnt work, try getting larger power cables.
I had the same problem with my 2500w xplodes all I had to do was get a thicker cable for the ground and battery connection. What was happening, was it was needing more power then the wire and fuse could handle, so it would blow the fuse, since the higher you have it, the more power it needs to feed the watts.
I would try grounding it directly to the frame on a good part of the frame before spending another $70 on new power cables though.
Mar 09, 2010 | Car Audio & Video
Lanzar vibe 256 battery wiring in my room, how?
try looking it up on you tube ive seen a introductory on how its done ..just type in how to hook up an amp in my living room i dont think you will need a battery..lol
Feb 23, 2010 | Lanzar VIBE256 Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
I have a lanzar vibe 255 can u help me?
Double check your connections. Use volt meter to co firm proper voltage. A test light can still light up with low vol
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Jun 28, 2009 | Lanzar Vibe 255 Car Audio Amplifier
Lanzar vibe 230 400 watts amp
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 27, 2008 | Lanzar Vibe 235 Car Audio Amplifier
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
My vibe 286 4000 watt lanzar amp wont stay on..
Mar 03, 2007 | Lanzar VIBE266 Car Audio Amplifier
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
