My advent pc keeps showing no signal when trying to load windows xp home replaced graphics card and psu
  • JDTec
    JDTec May 20, 2011
    Does the unit power up? Are you saying that there isn't anything on the monitor? Have you reseated the memory and cleared CMOS?
  • 394 Answers
HI,
Ones you install graphics card then the display connection with motherboard will not work.
1. Remove the display connection for your monitor from motherboard.
2. And connect it in Graphics card display port.
Hope it will help you.
Thanks for using FixYa.
Posted on May 20, 2011
A7600 GS TDH, Supplemental power supply problems, every time i load a game it also dosnt show the true graphics it shows some of it distorted, sometimes when i turn off my computer an restart it, i go to...
Hello there,
In Windows, it just comes up with a message saying it will be clocked down, so you just click "OK"? if molex is not plugged.
1. You should install the driver for the graphic card so it wont show distorted images, Microsoft display drivers are not reliable in gaming you may experience distortions.
2. Plug the molex or 4pin power to your card and observe if you will encounter the same problem after doing step 1.
3. If not try to test another PSU or acquire a new PSU that is powerful enough to run the card - not using the power cable could damage all your system.
Hopefully this information helps.
Happy Gaming
Thank you for using FixYa.
Aug 10, 2011 | Leadtek WinFast A7600 GS TDH GeForce®...
Had to load window xp on computer than try loading installation driver cd . it came up with error
1) Are you trying to install using Recovery CD and getting that error try installing Xp directly.
2) If you want to install Fresh windows, Boot pc with windows Xp and follow the instructions. And do full format your drive once where you want to install your XP, and continue installation..
Sep 18, 2010 | ATI RADEON 9550 Graphic Card
Blank screen after boot up
Remove the card, plug into your built-in card. Start your PC in safe mode. Uninstall all ATI software and delete the card from Device Manager. Restart. Reinstall the ATI drivers. Power down. Install the card and connect your monitor to it. The OS will find the card in default mode - let it. Restart. When it comes back up, you will be able to select the full range of operating modes.
BACK UP :)
May 03, 2009 | ATI RADEON HD 2400 PRO Graphic Card
BFG nvidia 6200 oc(overclocked) not showing bios
Your PC is still using your old graphics processor to boot up.
To change this turn your PC off. Hook you monitor up to the old display port. Turn your PC on and press F10 to enter the BIOS.
Select Peripherals > Int Graphics Processor and set it to PCI.
Save and exit. Turn your PC of, hook to monitor back to your new graphics card and you're all set!
BTW, 200 watts in plenty for that PCI card. nVidia always suggests more than you need to be safe. I had that same PC and card : D
Be sure to check out the amazing Z-Tweaked 82.12 drivers for that card (XP, or forced on vista and win7). The 185.81 by side are a step down but still very good (vista win7).
Apr 12, 2009 | Computers & Internet
Second hand PC Operating System/Monitor problems
Something located in the Motherboard may have burned up.
Probably RAM or Graphics Card
Jan 07, 2009 | Microsoft Windows XP Home Edition
"No Signal" on monitor after boot
hi try to use different slot on your motherboard see if that helps if not try different video card...if that didn't help it might be your motherboard that went bad
Aug 23, 2008 | HP Pavilion a400n (DQ173A#ABA) PC Desktop
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Pinnacle TV card will not work in 761mx (gx-968) motherbd. Pinnacle Ref: 203560713235309122. Windows sees and loads one driver, but original driver does'nt load.
http://www.twenga.co.uk/specs-PCTV-Hybrid-Pro-PCI-310i-PINNACLE-TV-tuner-card-114949
see the link
Software / System Requirements Software Included Pinnacle Studio QuickStart, Pinnacle MediaManager 1.1 OS Required Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition 2005 Peripheral / Interface Devices CD-ROM, DVD-ROM, DirectX 9.0 compatible sound card, DirectX 8.0 compatible graphics card System Requirements Details Pentium 4 - 1.8 GHz - RAM 256 MB - HD 5 GB
Jul 21, 2008 | Computers & Internet
Problem with computer
Try a good cleaning. Unplug the power cord from your PC. Remove the sides of your case. Using air blow everything off.
CPU, heatsink & PSU from both sides /outside to in & inside to out. Than remove the video card and clean its slot. Than clean the card its self. It would not hurt to remove your memory and clean their slots, reseat. Update windows!
If your broblem stops your done. If is hasn't doenload the latest driver from ATI: http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html Remove old drivers from control panel before installing new drivers. If your old drivers fail to remove. Download & run ATI's uninstall utility:
http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
Dec 26, 2007 | ASUS A9250/TD Radeon 9250, (128 MB)...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
