Question about Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16
I did not receive manual with the Optima 45 electric stapler. How do i get the slid to open to add staples?
  • 436 Answers
The slide tray is on the bottom of the unit.
to open, you just press the very front button on the bottom.
it should open right up.
I did not receive manual - newimage.aspx?sku=s7048209&h=200&w=200&u=px&d=72&c=&f=jpg&char=9&p=1&o=&imageid=
Hope this helps
Good luck
Please rate FIXYA
Posted on May 20, 2011
I have the Swingline Optima 45. I staple once then the light blinks and I have to open where you put in the staples close it again and it will staple once. Then I have to repeat.
Electric staplers are notoriously unreliable, but the problem you describe sounds like buildup of the adhesive -- a sort of varnish -- used to hold the staples in stick form for loading in the tool. Remove the staples and apply a light coat of 3-in-1 or other thin oil to the first two or three staples. Reload and cycle the tool. This should help you.
Jan 08, 2018 | Staples Tools & Hardware - Others
The auto stapling for my Optima 45 won't staple, can it be fixed? It will manual staple, but not auto. Kinda like the motion sensor went out. Any ideas??
Try to take all the staples out then put a small amount of "Two in one oil" as it is very fine oil. Once you have done this wipe off the excess oil if you have a lot spill out wipe with a rag & use the rag to wipe over the underside of one row of staples.
leave overnight & try to use this again with the slightly oiled staples this should remove any oil left then see if this does the trick. (Note I hope you have the correct staples for the machine of course.) Best Wishes Malcolm
Feb 23, 2015 | Swingline Optima Electric Stapler 45 Sheet...
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Staples will not come out of the stapler.
Did you use Optima brand staples? If not, the stapler will not work correctly. You must use their brand of staples or it will continue jamming, and giving you problems. The staples typically found right next to the Optima staplers in the office supply stores. They come in a rectangular metal box and are labeled Optima staples.
Sep 18, 2013 | Swingline Optima Electric Stapler 45 Sheet...
No staples coming out of machines
The Optima line of staplers do not work without jamming continuously unless you use the Optima brand staples. They can be found in the store next to the Optima staplers in a rectangular silver box, and will solve you problem instantly. There is no other brand of staple that will work in this line (I tried numerous), but once you purchase the Optima staples, problem solved, and you'll love it!
How to unjam
UNDO THE POWER SORCE AND OPEN THE STAPLE FEED PRY OUT THE JAMMED STAPLES "SMALL SCREWDRIVER SHOULD DO THE TRICK"
Dec 18, 2012 | Swingline 48209 Optima ® 45 Electric...
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
Jun 25, 2010 | Swingline 87850 Optima PowerEase ? Full...
Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
Mar 10, 2010 | Office Equipment & Supplies
Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16 Logo
1,049 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Van Allen II
Van Allen II
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
