Question about Sport & Outdoor - Others
I have a Walker Mower with a 20hp Kohler Command engine.. 850 hours on it.. I bought it used from a home owner.. This machine is using about a quart to quart and a half of oil on a full days use... it doesnt smoke except when the motor idle is changed during use.. or only for a brief second on start up or shut down... i have no Visable leaks. its been serviced by a walker dealer. new air filter, fuel filter, and oil filter and such...I was told that this could be a pcv valve or something to that point or even the valve guides.. if so .. where is the pcv valve ? Its not listed in the Mnaual.. and if the Guides are bad.. how serious of a fix is this..and what will I be looking for as a payment for fixing this problem....I was told to use straight 30 weight oil to help with this problem...should I be worried about this motor failing in the near future? thanks.. DAVE from Maine.
  • 65 Answers
SOURCE: fb460v kawasaki will not start
check your camshaft to see if exhaust loab has been worn off. have seen this before
Posted on May 02, 2009
  • 61 Answers
SOURCE: how to replace a PCV valve on my 1997 dodge neon?
Once you have the new PCV valve locate the old one on your engine. It will sit on the middle of one of your valve covers (most likely passenger side) and will have a line that connects to the top of the valve. Simply pull the old one out and put the new one in snapping that line on the new one. Should only take about a minute to do. Hope this helps, let me know if it does.
Posted on May 05, 2009
  • 420 Answers
SOURCE: high oil consumption on 2001 Toyota Highlander- 3.0 V-6 engine
If you are using that much oil you either have a BIG leak or your BURNING oil through bad rings
Posted on Jun 09, 2009
  • 32 Answers
SOURCE: Fuel Starvation Problem
Try taking off the fuel line from the tank to the carb and blowing through it
Posted on Aug 03, 2009
  • 138 Answers
SOURCE: Riding mower engine loud and smoking.
take it to a reputable shop and have them check it over - courage engines had a problem when they first came out - the bolts in the cover plate were not torqued properly and when they come loose, the torque of the engine turning will crack the block - this should be a warranty condition if the block is cracked - just make sure the shop is a kohler warranty station
Posted on Aug 28, 2009
Kohler backfires
This is a timing issue. Check the flywheel to make sure that it is not loose and that the woodruff key is still present.
May 25, 2013 | Toro ENGINE - 20HP KOHLER Part 93-1169
How many hours of use can I expect to get from this mower?
the more you do maint on it the longer you will get oil changes filters shape blades help engine load do you ever take off the top cover and clean the cooling fins?do you climb hills?use it to pull loads arouund the yard?but the 20hp kohler engine has had problems cracking the block on top of the engine my mower has a 22hp kohler with 2236hrs on it starting to get tired
Jun 07, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Hi, i have a 20hp high out put motor in my mower and it will only run with the choke out then it bogs down and stalls..checked fuel filter and its clean..any help would be appreciated..thank you
Most likely it is some sort of gunk in the carburetor. if it has been stored with gas in it this can cause this problem. You can try a strong dose of carburetor cleaner in with the gas. (Use fresh gas in the tank). and see if that helps. give it some time, but It may need a new carb or a rebuild.
Jun 23, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Have a brand new Husqvana with a 20hp Kohler V twin engine. Is it necessary to run the engine in? Nothing in the manuals about running in.
it doesn't hurt to ease it operation wise into service,but for sure do what the owners manual says to protect your warranty,and change the break-in oil soon to remove any machine shavings from the unit during the engine manufacture process
Mar 05, 2010 | Garden
John Deere Mower Engine Issue
HAVE YOU CHECKED THE CARB AT ALL? LOOK AT THE LINKAGE & MAKE SURE IT MOVES FREELY! IF CARB CHECKS OUT MAKE SURE GOVENER IS ADJUSTED RIGHT!!
Sep 05, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Sport & Outdoor - Others Logo
53 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
