Goodmans ld3261hdfvt, was flashing red light - fitted 17pw20.1 repair kit - now no responce from buttons on TV but set will switch on via R/C and shows osd CH number of button pressed but no picture or sound and no further responce to R/C or buttons on set
  • 308 Answers
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Posted on Jan 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: tz61v61 toshiba 61 rptv theaterview
If the relay clicks you most likely have a leaky diode or bad transistor in the stand by or start up circuit. There is a manual available for that model called. Toshiba Power Supply and Shutdown circuit Troubleshooter. Its available at the following link. It gives step by step instructions so you can figure out exactly whats wrong with your set. The site emails it too you after you place your order and they also provide free unlimited tech support so you will have a resource for help if you need it. I am one of their on line support techs. I highly reccomend that Manual to any one with a toshiba that will not power up. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
  • 5 Answers
SOURCE: TV Won't come on...
Hello to all from Tom Arnold, WA6OVP
Subject: Repair of computer monitors or flat panel TV’s.
History:
Recently my wife's 27-inch AKAI (LCT21AS) 27-inch flat panel HDTV with DVD player quit working. Years ago, when I had an analog computer monitor quit operating; Joe Fadden WA6DDF had mentioned to me, that often computer monitor problems were caused by the monitor's power supply. Joe also said these power supply problems were often caused by failed electrolytic capacitors. Joe said he was able to fix many computer monitors by just changing all of the power supply electrolytic capacitors. Rather the fix that failed monitor, I just a bought a new one.
Symptoms:
The inoperative HDTV had been bought at COSTCO and had already been returned once to a COSTCO repair center for repairs. Cost to ship and insure the HDTV was 67 dollars. We received back a new HDTV set. Turn around time was over a month, with many long distance telephone calls being required. The new HDTV worked for about three months after it was received. When the returned HDTV failed, it trapped a DVD disc that had been left in the HDTV DVD player. The new HDTV failure symptoms were the same as the original HDTV failure. The red led indication would not change to green when the remotes power on button was pushed. There was no picture and no sound. The remote is required to operate the TV set.
Economics:
My wife's HDTV with internal DVD player was very expensive. Worse yet, the trapped DVD disc was the movie Flash Gorden Space Soldiers 1936. A local TV shop wanted 85 dollars to look at the failed HDTV; repairs were 75 dollars labor an hour plus parts. I quickly figured out that if I could fix the problem it would save a lot of time and money.
Internet Search:
I checked the Internet to determine if other AKAI owners had similar problems with their HDTV sets. There were lots of AKAI 27 inch and 32 inch HDTV set owners listing problems. Without exception all of the complaints concerned the HDTV power supply PC board and failed electrolytic capacitors.
General Internet Consensus:
Most of the AKAI HDTV sets worked just great and that many had been sold worldwide. There were some AKAI HDTV sets that did have power supply problems. Most of the AKAI HDTV set owners were not very pleased with either AKAI or the COSTCO response to the inoperative HDTV power supply problem.
Trouble Shooting:
All electrical power was removed from the HDTV set. The HDTV was placed face down on a workbench with a piece of cardboard to protect the display screen. The HDTV back panel cover was removed. There were many screws of several different sizes. The power supply PC board was separate from the rest of the set's components and was easily identified. The power supply PC board contained several different individual different voltage power supplies. Three electrolytic capacitors located on the PC board had obviously failed. The tops of these three capacitors were puffed out. Often when electrolytic capacitors fail they get over heated and the top of the capacitor is puffed out displaying an over pressurized appearance. The power supplies on the PC board were of the switching type. Switching type power supplies are also used in computer monitors to save money and weight.
Power Supply PC Board Removal:
The power supply PC board was mounted to the HDTV back panel with several screws. These screws were removed. There also several multi-pin connectors attached to the PC board. These connectors were numbered with a black felt marker to ensure correct reinstallation. The connectors were Hot-glued in place. A sharp knife was used to remove the hot glue. The connectors were removed.
Repair:
The three suspect failed capacitors were easily removed. The three capacitors were each 1000 ufd and rated at 16 working volts. The other power supply PC board electrolytic capacitors were visibly checked. Three new capacitors were installed, they were rated at 1000 ufd at 25 working volts. On the PC board the three electrolytic capacitors were in just one of the power supply circuits and were identified as EC18, EC19, and EC20.
The New Electrolytic capacitors:
These were low impedance / high reliability radial lead polarized aluminum capacitors, they have a plus and minus connection pins. Correct installation of any polarized capacitor is required. The three new electrolytic capacitors were specifically designed and rated for service in switching type power supply circuits. Switching type power supply electrolytic capacitors need to be both very robust and designed for use in high frequency circuits. General-purpose aluminum electrolytic capacitors should not be used in switching type power supplies, if capacitors designed for switching power supplies can be obtained.
Final Repair Steps:
The PC board was reinstalled without the electrical connectors to the PC board being hot glued. The HDTV back panel cover was refastened. Watched episodes one through five of Space Soldiers. It was well worth the time and three electrolytic capacitors to fix the problem. The repairs saved a lot of time and money. The repair was very simple and not the least challenging. It took longer to remove and then reinstall the HDTV back cover panel than it took to replace the three failed capacitors.
Safety:
These types of repairs should not be attempted without a complete understanding of the dangers involved with working on electrical equipment, especially working around power supplies and charged capacitors. Proper desoldiering and soldiering techniques need to be used.
Conclusions:
Flat screen computer monitors and TV sets do fail. Repairs of electronic equipment can be very expensive. When your computer monitor or flat screen TV does fail, you might consider a visible inspection of the equipments power supply. A simple repair might save you a lot of time and money.
Posted on Aug 21, 2008
SOURCE: Sharp tv standby button wont switch on
have the same problem .please help.
Posted on Aug 31, 2008
SOURCE: RCA Model #32V434T no sound/picture
same as ak_medic
Posted on Nov 23, 2008
I have a GOODMANS LD3261HDFVT TV. It has been perfect up until now. Problem is that when i switch on I usually get a flashing red light instead of a solid red standby light. Sometimes if I get the solid...
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Please follow this step on how to fix that problem on your own..
  1. Open the back cover of your TV.
  2. Look at the power supply board..Its normally connected to the power cord..
  3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
  4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
I hope this solution will be helpful...
Thanks for using fixya...
This is the sample image of bulged capacitors
Dec 10, 2011 | Televison & Video
Does anyone know the sky remote code for my goodmans GTVL19W17HDF ? please
Hello
Setup codes for Goodmans TV with Sky remote are:
065 064 100 588 285 037 292 544 207 318 363 399 402 515 527 392 371 245 563 297 584 060 103 263 508 063 616 055
527
055
402
563
662
696
652
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 25, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Popping sound then tv went dead goodmans ld3261hdfvt. now tv wont switch on at all.
A lot of tv's do that when it overheats and makes a poping sound. check your fuse or call a professional to take a look
Jul 05, 2009 | Televison & Video
Proteam jumbo universal remote
Turn your device on.
Hold down the set button and press the button of the device you want to program (e.g. TV) then release the set button.
Press the set button again and the red light will start flashing.
Press the power button repeatedly until the device switches off.
This is now the correct code.
Press the device button once more to set the code in to the memory.
Hope that helps.
Nov 07, 2008 | Big Button TV Universal Remote
BUSH IDLCD27TV006
http://www.chsinteractive.co.uk/pdf_data/KT02.pdf
Order Code….. KT02
POWER SUPPLY REPAIR KIT
BUSH MAXIM 1157 1154 Medion
Goodmans (Standard) 04TA069I 05TA71B 05TA071C
A standard power supply repair kit for faults attributed to the standby +5v rail.
BUSH IDLCD27TV006.
MAXIM 1154, 1157.
MEDION MD30112.
GOODMANS IDLCD27TV006.
The numbers off the boards will read: 04TA069I 26” 27” 30” 32”
& 05TA71B, 05TA071C.
LCD TV POWER SUPPLY PROFILO-TELRA.
Please check the primary of TR20 before fitting the kit.
Primary windings should read approx 2.700mH / 4.00 Ohm.
We recommend all kits are fitted by qualified engineers
We accept no responsibility for loss, injury or damage caused by your use of this kit as a successful repair
depends on your own skill and fault finding ability.
Circuit Reference
Loc Description
F300 T3.15A FUSE
IC21 FSD200
IC30 ICE1QS01
D315 12V ZENER
D318 2V4 ZENER
Q300 BC337
Q302 BC848C SMD
D325 1N4007
C213 33UF
C322 47UF
C356 47UF
C330 1000UF
LINK (IF NEEDED)
Oct 31, 2008 | Televison & Video
Televison & Video Logo
203 people viewed this question
Top Televison & Video Experts
Electro Med Services...
