Question about Honeywell 3820 Wireless Handheld Barcode Scanner
My 3820 Handheld suddenly stopped scanning Follett barcodes. It beeps but doesn't scan. I've turned off the computer, rechecked all the connections, rescanned the programming barcodes--nothing seems to work. Any more suggestions? The scanner is about two years old.
2 Suggested Answers
issken
  • 1472 Answers
SOURCE: My 3820 will no longer
srodgers609
One of the problems I had with my scanner is that the USB port that I had the scanner in when bad. My scanner cable was a little short and it put extra pressure on the port. After time some of the connections in the port broke. To fix the problem I had to replace the USB card in the system.
So I would recommend that you tryu the scanner on another computer and/or another USB controller to see if it works properly. If it does you know that it is the USB port. If it does not then I would look at the cable of the scanner.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Aug 25, 2011
Barcode Scanner stopped scanning
These devices do fail, so that is most likely what has happened here.
Apr 13, 2017 | Honeywell 3820 Wireless Handheld Barcode...
My 3820 will no longer scan Follett barcodes. It makes several error beeps every time I try to scan anything
srodgers609
Issken
Aug 25, 2011 | Honeywell 3820 Wireless Handheld Barcode...
HOW DO I RESET A CORDLESS SCANNER HONEYWELL 3820?
I believe you can print the documentation and scan a bar code to reset the scanner. You can get the documentation here: http://lib.store.yahoo.net/lib/barcodescannersdiscount/3820UserGuide.pdf
Press CTRL+F and type "reset" to find sections on resetting the scanner.
Mar 02, 2011 | Honeywell 3820 Wireless Handheld Barcode...
LS3070 (ls3070-i000a) Handheld: My scanner stopped scanning. It beeps four times. ...
The four times beep means that there is an problem in the connection to the PC, please check the cables and configuration.
May 18, 2010 | Symbol LS3070 (ls3070-i000a) Handheld
Laser not working, screen won't show, beeps continuously.
i think i can help u with this, if u unscrew the unit and carefully unhook ur the cables in side then will see two Philips screws, unscrew them and unhook the display cable its on the side
now gently try to take the board out and put it back on then hook the display cable back and screw the board back and for the scanning
unhook and re hook ur scan cable that will make it work,i hope that will solve ur problem
Jun 11, 2009 | HHP Dolphin 9550 Barcode Scanner
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
Scanner won't read the barcode
you read the code base?
Try another computer, if it is the same, council liaison without base.Direct bluetooth.
Dec 17, 2008 | PSC Quickscan 6500 Handheld
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Honeywell 3820 Wireless Handheld Barcode Scanner Logo
1,423 people viewed this question
Top Honeywell Computers & Internet Experts
Ron Dufek
Ron Dufek
Les Morrison
Les Morrison
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
