Hi...I am trying to load my windows xp disc but my floppy drive keeps turning on...and I'm sure there isn't an xp floppy disc...how do I disconnect my floppy drive?
  • 393 Answers
Please follow the steps.
1. Open your PC cashing.
2. Floppy drive has two connections one is power cable and second one is connection with
motherboard.
3. Remove the Power cable That comes from your PSU/SMPS.
4. Remove the cable that is connected from the motherboard.
I hope it will help you.
Thanks for using FixYa.
Posted on May 20, 2011
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
Hi, I have a Creative Zen Touch 20Gb that isn't charging (USB or mains charger) and isn't recognised by the PC. It will turn on and play the music ok. I want to get the mp3 files off from the hard...
http://forums.creative.com/showthread.php?t=700611
The above thread contains a successful use of Creative with Windows 7, keep reading down the page. Other suggestions have been to try Vista drivers rather than XP. And there was the inevitable suggestion to use Windows XP mode on Windows 7 (but not all versions of W7 have XP mode.)
Aug 22, 2017 | Creative Labs Zen Touch MP3 Player
Restore disk has been lost. I need to know how to change bios to allow straight Xp to be installed
This isn't a bios setting, it's a setting that Compaq put somewhere (probably the MBR) of your OS to only allow it's restore discs.
If you want to use straight Windows XP OEM discs, just boot to the disc and you'll be able to install Windows. If that doesn't work, just format your hard drive(you'll lose everything) then boot to the XP and install that way.
Jun 11, 2011 | Compaq Computers & Internet
My wife Has a 7570 and my computer died taking all with it. It had windows vista loaded on it and PCD_WIN version 2.2 was working if you run as administrator. now the new pc has got windows 7 and have had...
Are you logged in as administrator? I'm not familiar with that particular software but most have the same sort of problems. In windows 7 you may need to 'take ownership' of the disk as administrator. Look at the 'exe" for her software in windows explorer. Right click on it and look at the security tab and see how it is set up. There and under the advance tab you will find settings including ownership, who can use.
Does the floppy work for other things? It may be that the pc isn't seeing the floppy drive properly. Try reading a different floppy and see if it also gives you the "no ID" msg. All discs have an ID so I'm not sure if this message is referring to the drive itself or to the floppy file. Look in CONTROL PANEL and make sure the PC is 'seeing' the floppy drive and showing that it is working properly.
Apr 23, 2011 | PfaFF Creative 7570
How to install windows xp in msi k8mm-v motherboard?
Hi dharmen_shah,
I see that you need to install Windows XP on you Dekstop with an MSI Motherboard k8mm-V.
I have another desktop using the same Motherboard, there are 3 options installing Windows XP on the machine.
  1. Using an IDE Optical Drive
  2. Using a SATA Optical Drive "not a common installation process on this motherboard" since you will need to install the SATA rivers first to be able to use your SATA ODD
  3. Using a USB Flash Drive
See steps below for each installation type.
*Using an IDE Optical Drive*
  • If you have your Windows XP CD insert it on the Disc Drive restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • Once in the Boot Menu screen select your Optical Drive, it may say dvd/cd or ODD, select this and press enter. Note: windows may restart during the installation if it says press any key to boot to cd do not press anything anymore leave it will do everything on it's own unless prompted for any user information like a computer name date and time.
  • You will see on the screen Boot to cd: then it will show "press any key to boot to cd" press Enter or any key this will boot from your cd Windows XP.
  • Then you will see inspecting your hardware for configuration, once it boots to your Windows XP cd you will see a blue screen Loading up drivers and stuff for the installation of Windows XP.
  • Next will be the installation of Windows XP itself, just follow the prompt it is very easy to follow and it will give you all the details and what buttons to click on.
  • Note: Select Quick Format (NTFS) this will be faster reformatting your Hard Drive before installation.
*Using SATA Optical Disc Drive*
  • You will need a 1.4 floppy disc to be able to do this.
  • If you have a 1.4 Floppy Drive you will also need to download the SATA driver from the MSI website.
  • Let us disregard this option since I believe you do no have a 1.4 Floppy Disc Drive and no one uses that or has a 1.4 Floppy Drive anymore on their machines.
*Using a USB Flash Drive*
  • To be able to use a USB Flash Drive for the installation of Windows XP your USB Flash Drive should at least be 1GB or 2GB, 1GB will be enough since windows XP only uses at least 7++gb of disc space for the installer size.
  • Using you USB Flash Drive you will need to copy the whole contents of your Windows XP Cd into your USB Flash Drive, don't worry this will be bootable just make sure that you copy everything from the disc into the USB Flash Drive.
  • Once you have copied Windows XP on your USB Flash Drive insert it to one of your USB ports on the machine then restart the computer.
  • Restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • This will be the same as using your Windows XP cd but instead you will need to select USB in the Boot Menu then press enter. on the installation steps it will be the same as installing using a disc.
  • Windows may restart during the installation and using a USB Flash Drive will be different at this point because it will boot directly to the USB, Once it restarts and may repeat the installation all over, to prevent this as soon as the system begins to restart from the installation go and keep on tapping "Delete" once it restarts this will bring you to the BIOS screen press F9 to set it to defaults then press F10 to save and exit this will restart again.
  • Once it restarts after setting the BIOS to defaults let the system boot on its own it will then show you a screen asking what windows to install the first thing highlighted will be the installation that was halted earlier just press enter then it will show you the windows installation page and will continue on it's own.
This is based on my own experience since I have an older Desktop that has the same Motherboard, I hope that I have given you all the options possible to installing your windows XP on your Motherboard k8mm-v.
Have a nice day,
mvincentc
Feb 02, 2011 | MSI K8MM-V Motherboard
Can't load SmartDisk FDUSB=TM2 on Vista Premium 64
Windows Vista carries a lot of glitches ....we need to give it more time as it improves. The XP environment works better with older technologies like the smart disk floppy drive. My advice is for you to partition your hard disk and place Windows XP on one side and still keep the Vista on the other. That way you can have both OSystems and still be able to use your floppy drive. Alternatively you can upgrade and use a flash drive storage or DVD/CD. They are newer technology which are more compatible with Vista.
Cheers & Kind Regards
Sep 02, 2009 | SmartDisk (RF-FDUSB-TM2) (RFFDUSBTM2)...
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
Motherboard drivers
I contacted HP the other day for a problem while trying to load XP on a VISTA box. They sent me to this site.. and gave me instructions for resoluation or at least an attempt.. Hope this helps
Thanks David
Let me know it if works for your problem
Solution: The reason for this error message is that notebook has been shipped with SATA hard drive i.e SATA hard drive controllers. But Windows XP does not have built in SATA controller drivers.
To solve this problem we need to install SATA Controller drivers before we install Windows XP using a USB floppy drive.
Many customers are not ready to buy USB floppy drive and installation of XP is so complicated using USB Floppy drive.
We have found the driver for the SATA controller on Intel Website. Customer has used it and installed retail Microsoft Windows XP with SP2 successfully on his dv6500 notebook.
The same can be achieved in all the dv2500, dv6500 and dv9500 also DV2600, DV6600 and dv9600 notebooks.
Here is the link for the SATA drivers:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&lc=en&softwareitem=ob-39535-1&jumpid=reg_R1002_USEN
1. The file contains the Intel Matrix Storage Manager Floppy Configuration Utility.
2. This utility will create a floppy disk containing the RAID driver files for installation on a 32-bit operating system.
3. This floppy can be used to pre-install the Intel Matrix Storage Manager driver during the F6 portion of Windows setup.
4. You needs Microsoft Windows XP with SP2 Operating System disc and the USB Floppy drive.
5. After downloading the SATA driver in another notebook, you needs to extract and execute the file. It will help in creating the floppy disk that has the SATA drivers.
6. Boot with the Microsoft Windows XP disc and make sure the USB floppy drive with floppy disc is connected to the notebook.
7. At the F6 prompt, select F6 to install additional drivers which are not in-built in the retail Microsoft Windows XP Operating System disc.
8. When the prompt comes up to install additional drivers, insert the floppy and select the correct SATA Driver. It is Intel 82801HEM/HBM SATA AHCI Controller.
9. Once that is done, the rest of the installation runs as normal. There are only 2 drivers in the floppy disc that would work.
10. After the Operating System is installed in this manner you can install the chipset drivers for the notebook.
11. However for the other device drivers once Microsoft Windows XP is installed you may not have them from HP as these series are not released with a Microsoft Windows XP Operating System. The drivers like audio, ethernet and media card reader drivers etc.
12. Please be sure with EU that he might not have the other drivers from HP after installing the retail Microsoft Windows XP.
Note: Do not click on the link. Copy and the paste the link into the address bar of the web browser.
If the above solution does not resolve the issue, please login to chat support with the results of the above troubleshooting steps. Also, please use the same email ID.
Dec 07, 2008 | Compaq Presario Notebook
Fdc corrupted
That error message means. You must have tried to boot up to a floppy diskette. The diskette ( 's ), were made with a defective floppy drive.To re-download the Setup Disks for Floppy Boot Install of Win XP click the link below:
http://www.microsoft.com/downloads/details.aspx?familyid=E8FE6868-6E4F-471C-B455-BD5AFEE126D8&displaylang=en
Option if you have a cdrom in notebook & a real Win XP CD. Put the win xp cd in the cdrom drive. Start the Pc laptop & press the F8 key every two seconds. Windows will display a boot up option menue. Choose the cdrom. Win XP will start the installation.
Feb 11, 2008 | Computers & Internet
PRINTER INSTALLATION PROBLEMS
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
