My Estudio 352 is set up as a network printer. I can select it as a printer and send data to it. It receives the data but does not print. The print log shows it received the data, but also shows that 0 pages were printed. I've downloaded the latest and greatest drivers. I've setup the printer every way I could find. I tried printing to the PCL, XPS and PLS, all with no luck. Any advice?
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
SOURCE: Hp 750 will not print.
Thank you for your promt reply but I have managed to get things going again as I got hold of the HP web site down loade an updted driver and found out what I was doing wrong. Basically my USB port for an HP Multi printer required an id of 'DOT4' rather than the LPT1 that it had latched itsel onto.
My problems started when XP Service Pack 3 downloaded and I lost funtionality with a few things, so much so now that it would appear that the registry is so full that my system has almost slowed to a halt and I am getting STOP errors after a period which means usually a restart. I have tried the Micosoft patches with little or no success and I am now looking at installing aother hard drive with the view to saving files to as I think my presant drive has been corrupted.
Cheers
Kazbo
Posted on Jul 23, 2008
  • 82 Answers
SOURCE: print was ready to receive data from computer but can't print.
i think your driver is wrong or your sofware
i hope i can solve your problem
Posted on Aug 26, 2009
  • 55 Answers
SOURCE: Trying to print from windows XP. Installed driver
unplug everything go to google type in the exact model and number of the printer and put driver after it and down load the driver then connect everything after the driver has been installed
have a nice day post nice things
Posted on Mar 06, 2011
  • 3278 Answers
SOURCE: Im tyring to configure an
Hello.
It turns out 4030 is an error code meaning "No print enabler/invalid" with the following corrective action: "Check if the print enabler is connected properly and it is inserted securely. Or check if the trial period is expired."
It's referring to a device (part GM1070) or a "dongle" that is needed to plug into your copier to be able to print directly off the network. I've seen new ones priced online around $500 (USD) or less for used devices.
If your printer is new or still under warranty, be certain that your supplier provides the print enabler / dongle.
Hope this helps.
Posted on Aug 26, 2011
I can't share my printer ineo+351 i don't have the
You must press Utylity/Counter next open on screen admin setting. (Pass is 12345678) next network setting, IP setting and you can set IP address. If network (card, cable, switch or router) are OK you can print on your Develop. Driver you find on www.develop.de or http://www.konicaminolta.eu/en/business-solutions/support/download-center.html
Nov 03, 2013 | Compatible Develop Ineo 300, Ineo 300,...
Toshiba estudio-352 "can't find HDD data" error
go to toshiba website and look for tech support and email the question to them they should get back to you asap.
Dec 26, 2012 | Toshiba e-STUDIO 352 Black and White...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Toshiba Estudio166 networking issue
Toshiba es166 is local USB printer. You can print from designated PC and you have to share printer if you want to print from other printer in your network. Because of low machine memory (16Mb) it could be some conflicts,if you use more than 2 PC in network. That is why Toshiba has es167 model on which you can add network print controller. You can also use USB hub if you want to print from more PC's. (only 2 brands of USB hubs provide this, see toshiba site)
Sep 17, 2009 | Toshiba e-STUDIO166 Printer
Estudio 352 is not help to take out printout from computer
Hello sir; When you make copy does it print? if there also no print out you better check the corona wire (charge & discharge) it should take care of you, if still don't work let me know.
Dec 30, 2008 | Toshiba Estudio 200L Copier
Scan to email
Go into the administration mode. Select network settings. Change your outgoing or SMTP e-mail server to the new source you are using.
Jun 30, 2008 | Office Equipment & Supplies
Printing Problems to my new Copier
TURN ON APPLE TALK IN NETWORK SETTINGS OF PRINTER THEN ADD PRINTER ON YOU COMPUTER.IT SHOULD FIND IT ON THE NETWORK AND PESTO YOU CAN PRINT
Jun 26, 2007 | Toshiba Estudio 200L Copier
Toshiba E350
Do you have the print option ? If not, you can configure everything, print jobs will show up on the cue, but they will just disappear into space. The print option looks like a USB key attached near where the network attaches to the copier.
May 01, 2007 | Toshiba e-Studio 350 Copier
46 people viewed this question
k24674
jasbo
jasbo
