Question about Minolta QMS 2200DL Laser Printer
Upgraded server to SBS2007 and 1 laptop both 64 bit, other comps 32 bit. Printer has network card built in but cannot get it to work. Connected it direct to server using usb to parrallel cable, printer recognized but will not print, data light comes on for 2-3 seconds then goes off, nothing then in the printer queue.
  • Minolta Master
  • 6,696 Answers
Self Help Product Support Konica Minolta Business Solutions Inc
try this site
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 21, 2015
3 Suggested Answers
  • 185 Answers
SOURCE: I just moved my office. My printer is connected to
Go to cameras and scanner in control panel and select scanner.
Posted on Mar 10, 2010
xeerie
  • 347 Answers
SOURCE: trying to install on WIN7
check the paper size.replace the usb cable.re install the driver.
Posted on Oct 28, 2011
Fujitsusiemens amilo a3667g
if you can go into safe mode with networking, get latest driver and make sure you download correct 32 or 64 bit version. 32 on 64 bit only partially works. if you can open up driver select the 64 bit version from update driver.
Apr 10, 2014 | Computers & Internet
Canon ip4500 problematic with win 64bit - seeking solution
Go to a 64-bit machine on the network and copy the 64-bit driver files to the machine
From the 64-bit machine, open Windows Explorer and browse to the 32-bit server
Open the Printers dialog seen via Windows Explorer.
From the Menu bar, select File > Server Properties, select the Drivers tab and click the Add button.
In the Add Driver Wizard, tick the x64 Processor checkbox, and untick the x86 checkbox.
Click Next, then click Have Disk and browse to the 64-bit driver on the local 64-bit machine.
Complete the Add Driver Wizard.
for more help visit CBR Tech Solutions
Dec 07, 2012 | Canon Pixma iP4500 InkJet Printer
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
Konica minolta di 1611, di 2011 driver windows 7 32 bit. konica minolta di 1611, di 2011 driver windows 7 64 bit pozdrawiam Jarek
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of BH 164 x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
Feb 10, 2011 | Konica Minolta Di2011
I am using A Iogear gpsu21 with a Kodak esp5 printer. I am able to print with no problem from a Acer AS1410 laptop running win 7 32 bit.I am using a Sony Vaio E series laptop with a win 7 64 bit system i...
First, make sure that the Kodak printer driver is properly installed in your Sony Vaio. Make sure that you can print while the Kodak is directly connected to Sony Vaio.
If you can print directly connected to it, try to reinstall the GPSU21 Utility.
Apr 13, 2010 | IOGear GPSU21 Print Server
WHAT IS THE OS FOR A TOSHIBA A 105 LAPTOP IS IT 32 BIT OR 64 BIT
this computer is shipped with windows xp 32 bit, can be upgraded to vista. As for 32 or 64 bit?, the only difference you will see between them is if you have more than 3 gig of ram installed a 64 bit O/S will see and use all the ram, where a 32 bit O/S is limitted to 3gig of memory it can address.
Personally, I believe you will have a lot easier time finding the 32bit drivers for your laptop and printer. 64bit drivers for older hardware are sometimes very difficult to find. GO with 32bit on this laptop.
Regards!
Apr 03, 2010 | Toshiba Satellite A105 Notebook
After adding a network printer which is on a Windows 7 computer - on a XP computer it is possible to open the printer but printing test page crashes windows explorer
Check your installed print server software for 32-bit and 64-bit versions. Both versions need to be on the machine that is directly connected to the printer, if you have a mix of the two types of Operating systems. 32-bit XP is very common and Win7 64-bit is becoming widespread.
(For HP printers using the manufacturer's UDP software, I found that if the printer was installed directly on a 64-bit Win7 machine, it failed. After installing the 32-bit software version in addition to the 64-bit, all the problems went away.) At least with the HP software, we did have a few minutes of confusion trying to find where the driver actually ended up. Double-clicking the downloaded file unpacked the drivers but didn't install them at the same time.
I hope this helps.
(obviously there are no firewall problems. I'll also assume the printer drivers were loaded without a problem on the two individual machines. This may have meant connecting it to the XP computer for a few minutes via the USB cable with some printers; consult your manual or the online support for the model.)
Feb 08, 2010 | Office Equipment & Supplies
Print server Iogear GPSU21 + HP Deskjet F4180 do not print!
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: http://iogear.com/files/pdf/GPSU21_Printer_Compatiblity_List_4-20-09.pdf . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
I hope this helps.
Jan 26, 2010 | IOGear GPSU21 Print Server
Gateway GT5222E windows Xp upgraded to Windows 7. Need upgraded video card, integrated video not compatable. Can I upgrade with video card?If so what can I get to do this.
Just go to best buy and find a video card that meets DirectX 9 Graphic specs that will fit you mother board.
1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
    Nov 11, 2009 | Gateway Computers & Internet
    Fargo DTC 550 driver for windows server 2008 64 bit
    Actually, Fargo drivers will not work on any 64 bit system - 32 bit only.
    Mar 21, 2009 | Fargo DTC550 Thermal Card Printer
    Minolta QMS 2200DL Laser Printer Logo
    42 people viewed this question
    Top Minolta Office Equipment & Supplies Experts
    Adorjani Laszlo
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
