Question about GE GTL16JBRBS Top Freezer Refrigerator
My frig is not geting cold. Freezer works fine, I don't have an ice maker and there is no ice build up nor is anything blocking the air flow. model gtl16jbrbs Thanks
  • 17,970 Answers
If the refrigerator is not running, first I suggest check to see if there is power to the refrigerator. Make sure the plug is properly seated in the socket and the temperature control is turned to the "on" position.
If "0F 0F" appears on the display, the refrigerator is in DEMO MODE. To exit Demo Mode for controls on the outside of door, Press and Hold the Energy Saver and Adjust Freezer buttons at the same time for 3 seconds. To exit Demo Mode for controls inside the Fresh Food Compartment, Press and Hold the Ice Off and Freezer buttons at the same time for 3 seconds. You will hear a beep and "0F 0F" will no longer be displayed. Adjust Refrigerator and Freezer temperature to the desired settings. Allow 24 hours for temperatures to stabilize.
If the refrigerator is running and not cooling or not cold enough, several factors may influence the temperature. Try the following:
* If the refrigerator has just been serviced, it could still be in a diagnostic mode. Please disconnect power to your refrigerator for 30 seconds and this should clear the control panel. The refrigerator should now cool normally.
Check the temperature control settings:
* For Dial or Digital Readout Models, adjust your temperature control by one number higher for a cooler temperature setting.
* For Actual Temperature Readout Models, adjust your temperature control by one degree lower for a lower temperature setting.
Additionally, for some troubleshooting tips, go here: Refrigerator-Troubleshooting
Keep us updated.
Posted on May 20, 2011
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
Freezer gets cold but refrigerator does not
blocked air flow from freezer to fridge. Could be ice build up. May have a faulty auto defroster. Freexer is only part that gets cold. The fridge gets it cooling from the freezer.
Aug 02, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
Help my frig is dying! The freezer compartment is working fine-but the frig compatment is nit colloing at all! What is wrong?
If the freezer is working that is a good sign. Here are what might be the problems; 1) Ice build up in the freezer will block air flow to the refrigerator and thus causing it to get warm and stay warm. If you observed a build up of ice in the freezer, it means that your defrost heater and/or your defrost thermostat is bad. In any case, replace both.
2) The evaporator fan plays an important role in circulating cold air in both freezer and refrigerator compartment. Listen for the evaporator fan and make sure that is running. If you can hear it, it has gone bad and will have to be replaced.
3) if any of the above applies, the lower or upper air dampers may be obstructed. Check and make sure that they are open.
4) Too much food or stuff in the freezer may also be the culprit. If there is too much stuff in the freezer, you might want to remove some them to make way for air to flow in the refrigerator compartment.
I hope this will help solve the problem. Do not forget "Feedback"
Jacques
Mar 24, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer works fine but fridge isnt getting cold
make sure there isn't food blocking the vents that bring the cold air into the frig from the freezer. and make sure they're open enough.
Jul 16, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Whirlpool side by side - freezer is fine. Fridge not cold
This is a common problem, and worth fixing if the frig isn't to old. The frig is making cold air just fine, which is a plus! All we need to do is get that air to circulate throughout the entire appliance.
Behind the freezer wall is a fan called an evaporator fan. This fan simply blows the air straight up the back of the freezer. From here it enters the frig at the top left and sinks to the bottom. Then it re-enters the freezer and continues its loop :D
So, either the circulation is being obstructed by something (maybe ice build up), or the fan is out.
Behind the freezer wall is the evaporator fan (that has probably stopped moving). Either ice build up (or some obstruction) has stopped it, or it has just served its time and needs to be replaced. Generally I would just replace it. You never know if it has been damaged from ice blockage or whatever the problem may be. If the motor is trying to spin and it is being held in place, bearing could be wearing out or completely gone which will just cause you more pain in the near future. So replace that puppy and you should be all set! :D good luck!
P.S. Naturally, if the fan is fine but you have something blocking the air flow, just fix the air flow problem in an apppropriate manor :)
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Ice Maker Not Making Ice
pls check the thermostat
Jul 23, 2009 | Refrigerators
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Duct from freezer to frig is blocked with ice, frig warm
give the unit a full defrost then unblock the drain hole. it sounds like the tiny defrost heater element may not be working and is therefore causing excess frost to build up on the freezer evaporator. also check door seals are not holled anywhere.
May 31, 2007 | Hotpoint HTR15BBMRWW / HTR15BBMRAA /...
GE GTL16JBRBS Top Freezer Refrigerator Logo
156 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
