Cost of replacement for AS02B012D24 power board for a ViewSonic monitor.
2 Suggested Answers
Alex93Serbia
  • 209 Answers
SOURCE: I would like to know
Viewsonic V170 LCD Monitor(China (Mainland)
Sir/Madame, please rate my solution, that would be really nice from you :)
Wish you best of luck, and rest of day :) Alex
Posted on May 05, 2011
Viewsonic VA1948M no power on
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Type in the brand name "Viewsonic" in the search box at the top right of the display window, to get gathered related posts.
Jun 26, 2015 | ViewSonic VA1948M LCD Monitor
I replaced the video board on viewsonic vx2235wm-5 now video turns on then off
That is a power supply problem not a video board problem. You will need to either rebuild or replace the power supply to fix that problem.
Oct 21, 2012 | ViewSonic VX2235wm LCD Monitor
We have a Viewsonic Optiquest Q9B-2 LCD monitor with built in speakers. Worked fine and all of a sudden wouldn't power on. We checked power cords and changed 3-470 caps, 1-330 cap, and 1-10 cap. Monitor...
Probably not yet. Check and replace the power transistor on the source board , it has been surely fried when the capacitors failed. If even after that the source doesn't start then the transformer has been fried.- you will have to replace the entire power board. This will cost you around $75. If you think your monitor is worth that much money then go ahead, replace the board.
If not...
Oct 05, 2010 | Computers & Internet
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
I need a part for my viewsonic vx910 LCD monitor, its basically a power unit . who can i contact or where can i go to order one, I live in australia. The sticker on this power board, is P/N AS02B012D24. I...
you can lcdparts.net and see if they have any. If not they could direct you to Viewsonic. If you have no luck let me know mwj71@bigpond.com and i will try my contacts for you.
Jan 03, 2010 | ViewSonic VX910 19" LCD Monitor
Viewsonic has trouble turning on-- seems to backlight (screen lights, makes an electronic hum), and then go to dead (yet the green power indicator stays on).
Hi, well if this is the inverter board, then its probably more cost effective to buy a new screen, same thing if this is the cathode lights. Reason for that is the technician will charge to replace, so cost will get anywhere from 50 and up. Only one question, how many years old is it? I do believe Viewsonic has 3 year warranties.
Nov 01, 2009 | ViewSonic VP171B (Black) 17 in. Flat Panel...
Viewsonic vx 715 the monitor turns off after 10secs through both vga and other cables on different pcs - the screen goes blank - when you turn the monitor off and on again the same thing happens - any...
Your monitor is probably shuttin off once something is heating up enough to cause the safety relay in its power supply board to shut it off. I find that once a monitor goes, just toss it, it isn't cost effective to try and have it repaired the
cost will exceed the cost of a new monitor
Sep 13, 2009 | ViewSonic VX715 17" LCD Monitor
Screen won't stay on
This is a common problem with LCD monitors after a few years of use. The capacitors in the power supply board start to fail and this prevents the monitor from starting up correctly. Sometimes you get a picture and then it goes black. On some units you can keep pressing the power button and after several power up cycles the monitor will work until you turn if off. These symptoms are all common with capacitor failure. The monitors are well out of warranty now so Viewsonic will not cover the repair cost. But the repair is very easy to do yourself. You just have to replace the 6 power filter capacitors on the power supply board. Here is a link to additional information on this repair.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=218
I hope this helps, I have repaired over 30 of this model with the same issue.
Mar 28, 2008 | ViewSonic VA902b 19" Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
