Question about Acer AL1711 17" Flat Panel LCD Monitor
My Acer AL1711 goes black but the light indicator on..i've read some of comment similiar to my problem and tried to repair it..but still..it didn't work..i even replaced the 1000uf capacitor..but it still the same..some said it had backlight problem causing it to goes black..should i change the capacitor?
  • 11,361 Answers
When you repalce the caps, they should be repalced in a set since bad caps can look normal but can have high ESR.
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL1711bm/
And yes, you can have bad lamp assembly:
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
You need spare lamp the test the inverter board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 21, 2011
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at tech@ccl-la.com
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
My acer laptop screen goes black after i pass the log in screen
What you can try to do is hit "Ctrl" + "Alt" + "Delete" which should open task manager once you've reached the black screen. Click "File" from the menu bar and then "New Process". Type "explorer" in the box, and, Voila!, you should be able to see things again.
Sadly, this is indicative of a virus or corruption of the operating system. I'd recommend backing up all your stuff and then tapping "F8" while you're computer is turning on, hitting "Enter" on "Repair my Computer", clicking through the dialog box, and then select the "Acer Recovery" option. This will wipe everything back to factory defaults.
Aug 24, 2011 | Computers & Internet
Acer monitor AL715 blacks out after seconds. Can see screen again for seconds if shut the monitor off and turn it back on. I get a picture when attaching the computer to a projector.
The screen resolution on your PC video card is set to high, the Acer monitor (rather than giving you ANY indication of whats wrong) just goes black. If you have another monitor, hook up to it and lower your resolution. You can also try going into safe mode and resetting your resolution there or deleting your video card and then on reboot into normal mode allowing it to re-install, where you could then reset your resolution.
Feb 20, 2009 | Acer AL1711 17" LCD Monitor
Monitor goes black after a few seconds
I have the same problem on my Acer AL1711. The monitor was out of warranty so I opened it up and found one of the 1000 mf capacitor almost ready to pop. A 50 cents replacement from allelectronics.com fixed the problem.
Not recommended for anyone without experience soldering electronic components to PCB's.
Dec 11, 2008 | Acer AL1711 17" LCD Monitor
Acer al1711
We have repaired a couple of these. R1 on board normally burnt also C6 and C22 bad on inverter board. Replace these and it will probably work. R1 is 10 ohm. Capacitors are 220uf 25v.
Nov 07, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
What is wrong with my AL1711
This is possibly an inverter. When the monitor goes out, examine the LCD to see if you can see a faint image of the video being displayed. IF so, replace inverter. If not, possibly a bad LCD or video circuitry.
Dec 07, 2007 | Acer AL1711 17" LCD Monitor
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Acer 1711 LCD Monitor
My Acer AL1711 packed up last week, I bought a new Acer and noticed they have a 3 year warranty. Give Acer a call on 0870 853 1000, and they`ll do a warranty repair with free pick up and return - great service! Not sure if you need proof of purchase or not, luckily I had mine.
Apr 09, 2007 | Acer AL1711 17" LCD Monitor
HELP!! ACER AL1711 On and Off forever
Most of these have inverters that power the LCD monitor more than likey that is what happened! These can be repaired, but you will get charged an nominal amount. Better off getting a new one! You better get one soon, 17" monitors will soon be out, they will no longer be sold as the standard will soon be 19".
Nov 17, 2006 | Acer AL1711 17" Flat Panel LCD Monitor
Acer AL1711 17" Flat Panel LCD Monitor Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
