Device is not working properly, the light comes on, but it does not show up on the desktop, or anywhere on the computer. I have tried on different computers, and have used different firewire cables, nothing works.
  • 27,725 Answers
Sounds like a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Posted on May 20, 2011
My toshiba 8 gb pendrive is not recognised by desktop,
does this pendrive work on other computers if it does then use a different usb port if it wont replace pendrive
Aug 01, 2014 | Microtoolz PenDrive Autorun
Iomega External Hard Drive is not recognized or not detected. External drive does not appear on the desktop. I have had this hardrive for a while and it is about at half capacity. When I plug in the USB to...
Yes, seems that the USB controller is not working properly, Try buying an external HDD case and insert your HDD into it. Its just a plug and play setup. Hopefully it will fix your problem.
Jun 10, 2017 | Computers & Internet
My pc shows only a black screen that says Rebboot and select proper boot device or insert boot media in selected boot device and press any key. i cant get anywhere with this what can i do i am on...
first check the power supply to the booting device and also the interface cable then switch on the computer touch the booting device and see the device is working next see if the device is marked in the bios a primary master or slave or secondry mastor or slave if not shown change the power and interface able and try once more still not showing change the booting device
Sep 04, 2011 | HP Computers & Internet
My hardrive is plugged into my mac, the light is on, the hardrive is spinning, but no icon shows up on my desktop. I've searched my computer, and the icon isn't anywhere. I don't know how to access it...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 18, 2010 | FireLite (USBFLB80) Hard Drive
My LaCie external hardrive doesn't show on my desktop anymore when I plug it in. This just started today yesterday it was fine, but now the light doesnt even come on
First try to plug it in to a different port on your computer.
If it still doesn't come up, reboot your computer, Still not working? Try connecting it to a different computer.
If the drive still doesn't come up on the other computer most likely the case/ housing will need to be replaced.
Oct 15, 2010 | Office Equipment & Supplies
I baught a Sensei 2GB mp3 player. Pink. When I ...
You need to turn on the device and then it will be recognized.
May 21, 2010 | Audio Players & Recorders
Will not show up on the my computer screen but device works right
You could have changed the OS that the device was running on. Try unplugging device, then turning off computer and plugging it back in. Then restarting computer, that should work.
May 12, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
My USB-250 GB toshiba unit is not showing up on my desktop
Sofia;
Try booting up the computer you want to use the device on, with the device plugged in. (also this external hard drive should be powered by your USB bus alone)
Let me know if this helps
Jan 05, 2009 | Toshiba Computers & Internet
Firelite 160gb HD not recognized
Make sure that there is no "HD protection", in which the hard drive can only be connected to one computer. Also, try going to google and searching for some drivers for your computer to download and install. Then try plugging your hard drive in again.
Dec 28, 2007 | FireLite (USBFLB80) Hard Drive
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
