Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printing with my Kodak easyshare 5300
the attention light continues to blink. The LCD display says "color ink cartridge needs replacing - replace color ink cartridge." I seldom use the color cartridge, so do I have to purchase a color cartridge to use the black ink cartridge? And how do I switch between color and the black-nd-white cartridges?
  • Anonymous Mar 15, 2014
    can't print black with color cartridge empty
  • 6,487 Answers
You cannot print if other cartridges are empty, that's how this printer works.....
Hope that helps......
Posted on Aug 14, 2008
    Master:
  • 521 Answers
It is necessary to install the colour cartridge.to use with black
  • tech expert12 Aug 14, 2008
    though you rarely use the colour cartridge, you have to install the colour cartridge because in your printer both the cartridges should be installed and working properly even though you want to work with the single cartridge.and if you dont want your colour cartridge to be used at all then right click the printer icon and go to properties and set the option as "print in black only" so your colour cartridge wont get used. thanks and do rate the solution.
The printer only prints in black, white and yellow. I have replaced the color cartridge twice and it continues not to print in color.
Here are the basics to check from Kodak:
Verify that the ink cartridges are intact and securely inserted into the printhead, then make the same print.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
Hope one of these solves your problem.
Feb 01, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I've been using my scanner this am, now the attention button keeps blinking that i am out of ink, I haven't been using the ink, just the scanner. I can't even shut down the printer. kodak all in one...
Kodak printer are designed in such a way that if you even don't print from them, everytime you on-off the printer the cleaning process goen on, which results in emtying the ink cartridges. Try installing new ink cartridges. if u still get the same ink error. Then the printer will be replaced.
Jan 14, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
We cannot get out printer to print. easyshare
we replaced printhead and it wants us to calibrate and replace ink color ink cartridge, and before we put the printhead in , it had 1/2 full color in cartridge
Jan 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 All In One Printer. Black ink quit printing.
Hi there.
It could be the chip in the cartridge... faulty for printing?
Settings in the printing process?
Iceman.
Nov 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak easyshare 5300 will not print right color on
press the menu button on the printer and go to clean print head and do a basic clean........make sure you are using genuine Kodak ink cartridges as there are retailers selling refilled and look alike.........if you still have same issue then its a print head issue and call kodak tech support they will replace it for you without any charge....let me know if this was helpful.........
Jul 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink level will not reset when cartridge is replaced
If you take the cartridge to walgreens, etc... they can clear the chip. There is none for home use
give them a call !
May 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer Kodak Easyshare 5300 Will not print black ink
They overnighted a new printer head and free ink. We already recieved it. AMAZING. Thank you Kodak. They are awesome.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Changed ink cartridges Kodak 5300 print blurry/missing letters
I called Kodak and they are sending me a new printer head at no charge! Can't get any better then that. Man I talked to was very nice, knowledgeable and polite.
Dec 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
My kodak 5300 will not accept the new ink cartridges
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
433 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
