I have an nice tel pm-rc4 universal remote that i would like to use on my admiral tv so i can get to the menu to put on the closed captions on the screen since i since become hearing depaired. i do not have the original remote for the television and there isn't a control panel on the tv to get to the menu screen. could you please help me get the code and instuctions to program the remote. thank u so much!!!!
SOURCE: closed caption for durabrand
if you have the menu button on the tv itsself then you can go from there to remove th closed caption
Posted on May 12, 2008
  • 3 Answers
SOURCE: ilo tv/universal remote codes
Here are some to try, mine was 0189, but there are many to try. 0051 0189 0053 0198 1070 1024 1023. I think some listed codes for Emerson work as well.
Posted on Aug 06, 2008
SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there.  Worked for us - got the idea from another fixya post.
Posted on Aug 28, 2008
Benimur
  • 6966 Answers
SOURCE: code for haier tv to program with rca universal remote
Hi and welcome to FixYa,
For the manual of an RCA CRK76TA1 remote control, pls click here. It is a pdf file and would require Adobe Acrobat reader.
Offhand am not sure if an RCA remote would work with a Haier television. You could of course still try: 140 191 0000 10748 0001 002 003 004 005 006 085 086 223 323 2000.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 04, 2008
Tech5508
  • 40 Answers
SOURCE: need codes for universal remote for ilo television
I dont know which remote you are using but you might want to try these 2 codes... 0171 and 1990
These codes are also mentioned depending on which universal remote being used ...
10180 10171 10171 10179
Good Luck.
Posted on Feb 10, 2009
Can't turn on memorex MT2012 Closed Captioning using a universal remote
You must have its original remote control, which will have 'CC; button on it. you have to press this button once to cancel the Closed Caption option. If you can acccess the Menu of the tV by your present universal remote contro,; get into TVs Menu option, surf through, come to closed capation adjust window, and cancell [OFF] the closed caption option.
Apr 08, 2012 | Televison & Video
How do i turn on the caption with universal remote RCr311W to a sanyo tv moel#DS27820 ?
Here is the link to the User's Manual for that universal remote control:
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/RCR311W_DOC_OM.pdf
Unfortunately there is no dedicated button on that particular universal remote for operating the Closed Captioning feature on your TV.
You can try using the MENU button on that remote in order to access the AUDIO OPTIONS on your TV. Then see if you can activate the CLOSED CAPTIONING from there. See page 5 of the above manual for instructions on how to operate the MENU button on that remote.
Otherwise you will have to use the original factory remote control that came with the TV, or go out and buy a more expensive / advanced universal remote control with all the additional features and buttons that you require.
Good luck.
Joe.
Dec 09, 2011 | Sanyo Televison & Video
I have no remote, how do I get off close caption on a TS2554C101
There is a Menu button on the TV for the TS2554 C101. Press this button to get the OSD menu. Then press the vol +/- buttons to highlight Set. Use the Ch +/- buttons to get Closed Caption. Then press Vol+ or Vol - to get the closed caption menu. Use the Ch+/- buttons to set the desired closed caption setting and then press Vol + or Vol - to confirm the selection. Press Menu again to exit.
This will only help if the captions are being interpreted by the TV. If there are open captions, they will not go away. If the closed captioning is on at a set top box, you will need to turn them off using the controls for the set top box. (I know satellite receivers have independent captions available.)
I hope this helps. If your TV doesn't have a menu button on the set, you will need a remote that has a matching Menu function. Some universal remotes should have this feature.
Apr 28, 2011 | Philips TS2554C 25" TV
I can't turn the closed captioning OFF on my insgnia flat screen tv model NS-L CD37. i have a universal rca remote & the closed captioning won't go away - HELP !
The problem is that the universal remote is not sending the correct IR signal to your units IR receiver, regaurdless whether or not you turned the captions on with the universal, it is unable to send the signal to turn them off, if you have a menu button on your unit you could try accessing the closed caption option that way, alternatively you can do a system reset, if you can access that menu option, you may need to do a tv retune to get your stations, but the closed captioning should be off. I hope this helps. Good luck.
Jun 07, 2010 | Insignia 37" LCD Flat-Panel HDTV
OBTAIN CLOSED CAPTIONS WITH UNIVERSAL REMOTE
can;t with universal need to do it manuelly in main menu
May 05, 2010 | Prima C2012 TV
I do not know how to turn off the closed captioning on my son's orion tv set. I do not know the model type. I do know that closed captioning options are not on the menu.
If you have the original remote look for a button labeled "CC" or "Caption/Text" press this button till the screen says caption off.
Jul 06, 2009 | Televison & Video
Closed caption for durabrand
May 10, 2008 | Durabrand DWT1905 TV
No remote to turn off Closed Captioning
if your tv has a menu button on it enter and try ot turn it off via thr front control buttons
Apr 07, 2008 | Philips Magnavox Learning Universal Remote
TV REMOTE PHILMORE PM-RC4
irie breda.
go this homepage and u can find too many codes for pm-rc4
http://www.hifi-remote.com/ofa/codes-tv.shtml
saludations.
kings of kings
lords of lords
jah rastafarai
Mar 26, 2008 | Televison & Video
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Electro Med Services...
