Question about Garden
Hi. This is my first time that I have a Murray 20" 3.5 hp lawn mower machine. I don't know if I have to put together the Oil with de Gas, or I have to buy a special liquid to star the machine. Can you help me , please
  • 582 Answers
See if you have an oil fill plug on the bottom of the engine if you do you donot have to mix oil
also look on the top of the engine and see what the engine is if it says 2 cycle you must mix the gas and oil hope this helps
Posted on May 20, 2011
Testimonial: "Thanks... That will help me"
  • 407 Answers
Hi,there is no need to add oil to your gas.Use just gas in the fuel tank,and sae30 oil .There is a primer bulb,it should be red.Fill the tank with gas then you press the primer bulb 3-6 times and pull the rope.On the top of the machine is a picture of an oil can,looks like a djinns lamp to me ,the dip stick is in there and that is where you put the oil.Make sure you do have oil in there.
Craftsman Briggs & Stratton lawn machine engine 6.75HP don't start no spark
Take of the hood and shine up the magneto and if that don't work the take thecarbrator of and where the primer ball is unscrew the Philips head screws and that will release the primer from the gas tank and there will be a little screan blow that out then put it all back together push the primer button 3 times the pull the cord to start the mower and it will run if that don't work then let me know if you want to get ride of it please because my hobbie is working on mowers thnks please respond back thanks hope this helps you problem
Apr 19, 2013 | Garden
How much oil dose a push mower hold
most lawnmowers have oil in the crankcase and you don't put oil in the gas. but if you have a 2 stroke engine you will need 2 ounces for every gallon.
Sep 07, 2012 | Husqvarna 675 hp 21" Honda Rear Bag Push...
I have a yardman 6.25 hp lawnmower what type of oil do i put in it? the oil is seperate from the gas. Sorry i am unsure can u please help me.
Put in about 20 oz. of SAE 30HD oil. I recommend synthetic, and if you use that, you can use a 10W-30 oil. Remember, a quart bottle is 32 ounces, so DON'T overfill.
Sep 02, 2011 | Garden
2 or 4 cycle oil for a Ranch King 6.0 lawn mower? What kind or type of oil should use?
If you mean oil for the crankcase use need 4 cycle oil Ususally 30 weight and don't over fill Most small engine do not even take a quart only about 20 oz.
If you mean to mix with gas ( I doubt this) but then you need 2 cycle oil depending on the mixture usually about 3 oz to a gallon of gas (3.2 oz / gal = 40:1 ratio, 2.5 oz/ =50:1)
May 24, 2011 | Briggs & Stratton Garden
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Apr 11, 2010 | Garden
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Engine shuts down
check compresstion.if good check valve if good check beather on engine.but first check
sparkplug.let me know if this help you.ok
Jul 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Mar 27, 2009 | Garden
Garden Logo
342 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
