Question about Microwave Ovens
Need instructions on how to work norfrost c4cfw-h freezer
Zanussi freezone fridge freezer
Try adding freeon made for refrigerator. Can get at any hardware store. Hope this help.
Sep 09, 2013 | Microwave Ovens
Frig or freeser not cold
If it is your freezer, check to make sure that the air vents inside the freezer are not blocked by food. Putting too much food in an blocking the air vents will prevent the freezer from freezing. Air needs to circulate inside the freezer for it to work properly. This can also cause excess freezer ice collecting on freezer or in foods. Dust and lint will collect under and behind a frig. Pull the frig out from the wall, unplug it. Check for lint under and on the back of it. If it has accumulated some, vacuum it all off and plug it back in and wait a while to see if it gets cold. The fan pulls lint and dust under the frig and it stops the cooling system. If this doesn't work, it may need the freon (can't spell it correctly) stuff replaced. If these don't work, you need to call
Feb 15, 2013 | Microwave Ovens
I have a sterling 5 quart ice cream freezer. I need to replace the canister lid
Here is a tip that I wrote that will help you with getting parts and manualsfor your Ice Cream Maker
Ice CreamMaker Parts, Instruction Manuals and Recipes
heatman101
Jul 26, 2011 | Microwave Ovens
Freezer works but frig not cooling
if you were to reach your hand towards the rear inside the fridge area can you feel cold air blowing into the refrigerator side if not this could either be due to the fan inside the freezer area not working or there is a small door that is controled by a thermostat inside the ceiling of your refrigerator this thermostat when it reaches a tempreture that is to warm it opens a small door in the rear that connects to the freezer allowing cold air to come into the refrigerator side when the refrigerator becomes cold enough the thermostat then shuts the door. You could also have a defrost issue inside the freezer area in which u would need to remove the rear panel in the rear of the freezer in order to assure you did not have this issue. If you remove the rear panel and you see any ice build up on the evaporator coil (note this is also where the fan that blows the cold air into your refrigerator is located)you would have a defrost issue. If you remove that rear panel and find any ice build up message me back and il instruct how to fix but first check to assure you have air blowing into the refrigerator side. If you dont then you have to diagnose which is causing the issue either the fan which you could hear if you listened inside of the freezer area or the door itself is not opening due to a malfunction with the thermostat if you have any further questions message me back and please also remember when our chat has fully conlcuded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks
Rick
Jun 24, 2011 | Microwave Ovens
How do we reset our freezer? Is sitting at -20 C and cant set it, way too cold. Can you tell me what site l can get onto to downlowd the user manual l have misplaced mine. Need attention asap.
Minus 18 is correct for a freezer so minus 20 isn't far out.
At minus 18 or Zero Farenheight, is where bacteria stops developing and food keeps for years.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
I hope this helps.
Jan 16, 2011 | Microwave Ovens
Hi there. I have had my fridge freezer for about 1 and half year,but the fridge is not working.The freezer works perfectly fine. can you help please? Thnx
I suggest that half of the system is not working and recommend the services of a refridgeration engineer as it may need re gassing.
Jan 08, 2011 | Microwave Ovens
Ice and frost on coils inside freezer
Possible that the auto defrost timer is faulty and is not working to the scheduled timing causing the frost to build up and block the coils in the freezer.
You will need to check this timer at the rear bottom of the fridge , check if thee timer clicks on or else replace,
Make sure that the thermostat is also working and shut the compressor when the thermostat is set low.
Sep 27, 2010 | Microwave Ovens
My freezer is working but the rest of the fridge is hot
Hi, it is possible for your freezer to work when you fridge is not working. Fridge-freezer appliances have independent controls which can malfunction separately. If your freezer is fine and your fridge seems down, there are several things that could be wrong but what i suspect is that... You should check the damper door located between the freezer and fridge compartments to make sure it opens and closes, sometimes they get an ice build up there and this causes them to stick shut, remove ice with hair dryer or remove and device and replace this will solve your trouble.
Best of all is to call in a local fridge technician around to get it fixed, it won't cost you much...
Take care
Feb 18, 2010 | Magic Chef Microwave Ovens
The freezer is working fine, I have removed the floor plate in the freezer to check if the drain was clogged and it was frozen but I removed it but the refrigerator is not cold. I checked the door switch...
Please reply with a model #, make, and what exactly is the problem?? the fridge part is warm?
do you hear the compressor running?
is the freezer the correct temp?
Thanks!!
Aug 14, 2009 | Microwave Ovens
Microwave Ovens Logo
128 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
