Question about KitchenAid Refrigerators
We have a double door freezer on top, refrigerator on bottom. Water has been collecting on the shelves on the left side of the refrigerator. It appears that there is some sort of a vent at the top of the refrigerator section in the back. What could cause this and how can we stop it. There is an amount of water to soak a paper towel per day.
    Brigadier General:
  • 3,917 Answers
You most likely have a plugged drain tube. First unplug the refrigerator. You will need to remove the back panel in the freezer and locate the drain tube and to defrost it. This panel is quite often a two piece panel that is held in place with 4 or 5 screws or 1/4 inch nuts. If the lower panel can be removed without removing the top panel, this is ideal. Remove the bottom panel. The drain is located on the bottom of this area. If it is plugged, the depression under the coils will be filled with ice. The ice needs to be melted. You can leave the freezer door open for natural defrosting. Also you can use hot water from the faucet. Do not heat water; boiling water could damage certain components in the freezer. Place a couple of bath towels on the bottom of the freezer. Place a large bowl of hot water on the towels. Using a turkey buster, pour water on the ice. Do this about every 5 to 10 minutes until the ice is melted. This should unplug the drain in the bottom of the back panel. When the ice is thoroughly melted. The drain can be inspected. When you pour water in the depression, it should drain immediately through the drain hole allowing for water to drain down, or clear all the tube leading down to the drain pan.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 20, 2011
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water collecting on the shelves
Sure are a lot of sweaty fridges out there. My wife complains about it too. A mis-fitting door will allow moist air inside. Brute force usually fixes that. I just put my foot against the door bottom and bend the door back to where it belongs. If it has drooped, try just forcing it back up. And don't keep the door open too long when looking for stuff.
Apr 11, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
43 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
