Question about Air Tools & Compressors
What is the difrent between LRA and BTU ? - Air Tools & Compressors
  • 436 Answers
One really has not much to do with the other directly
BTU - British Thermal Unit.- A heat measuring unit. IE:12,000 BTU (British Thermal Unit.) The amount of heat required to melt one ton of ice.
LRA - Lock Rotor Ampere-LRA is nothing but locked rotor current , generally it is located on compressors name plate, when ever pistons locked at a particular position the rotor does not move further at the time rotor draws large current, that current is located on name plate, by seeing that LRA we can know compressor rotor was locked
Posted on May 20, 2011
    New Friend:
How to calculate the capacity for the unit using LRA
Posted on Aug 20, 2017
So far i didn't get watts on my compressor explaning LRA-does not help ! becouse don't have number to multiply by 220 V in order to get replacement supplyer need watts !
RLA= Rated load amps or running loads amps depending on mfg.
FLA= Full load amps
LRA= Locked rotor amps.
watts is voltage times current, So use 220 time the LRA get that watts or 220 times FLA to get that watts and
multiply 220 times RLA to get watts.
Nov 02, 2017 | Heating & Cooling
How many LRA in 20562BTU
That makes no sense. LRA is going to be for a motor or compressor. I've never heard of a 20562 BTU machine. You have to read the data plate on the machine, either indoor or outdoor unit will tell you. If you can't read the data plate turn the power off and look at the data plate on the actual motor itself. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 16, 2017 | Heating & Cooling
LRA how to convert in tonage so 10 LRA How many ton and 145 LRA Copland scroll compressor tonage value pleas give me answer
LRA on the data tag stands for "locked rotor amps" and has nothing to do with tonnage. In the model # there should be a number to use. And divide that # by 12 (12,000 btu/ton). So if I had a PFG24H200 it would be the "24"and a 2 ton unit
Jul 06, 2015 | Heating & Cooling
How to find out tonnage from lra
There is 12,000 Btu per ton. Multiply The voltage by the amps (current draw), that equals to watts. Multiply the watts by 3.413 and that is your Btu. Then divide by 12,000 and that's your tonnage.
Aug 28, 2013 | Heating & Cooling
Tonage or BTU/hour rating from Ruud name plate
See this link
http://www.epinions.com/specs/pr-GE_Zoneline_AZ55H07D_Air_Conditioner
Its say 7100 BTU/hr
Jun 05, 2009 | GE Zoneline AZ55H07D Air Conditioner
What is the cooling btu on my BDP company division of carrier
is this unit real old ? it does not come up in my book . the btu is 30000 that is the same as 2.5 ton it may be 6,7 or 8 seer i dont think its a 10 seer because the 10 seer units are listed and yours is not . if this sounds wrong please look up the mod # again and post the ser # too ......... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 15, 2009 | Amana Comfort Zone 12M32PBEH Air...
Air Tools & Compressors Logo
814 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
