Question about Lexmark Office Equipment & Supplies
Not sure how to work my scanner,properly to scan and put my information in it's proper place
  • 24 Answers
Hi jhannah3,
what's the brand and model of your scanner or all in one printer?
Scanner and Multi function printers also called all in one printers comes with their own scanning software that you can install into the computer, even windows now has its own built in scanning program that you can use, generally, you just have to put the document or picture that you want to scan on the glass plate and press the scan option on the program that you are using although different brands have different implementations as well, if you want live assistance, try calling this number 1-877-787-8749, I forgot their name but they could walk you through the steps that you need to do.
Cheers,
Posted on Aug 14, 2008
The scanning software could not be found, or your scanner is not connected. please make sure you scanner and your scanning software are properly installed
the scanning software could not be found, or your scanner is not connected. please make sure you scanner and your scanning software are properly installed
Oct 23, 2010 | Acer Scan to Web 3300U Flatbed Scanner
My scanner sometimes crops a particular slide but not others. Some scan ok. What is going on?
Be sure to put the slide in the holder in the proper direction. The opening in the slide holder is rectangular, not square like the slide. If you place the slide in the holder horizontally and the holder window is vertical, it will crop off the sides of your picture.
Jul 20, 2010 | Plustek OpticFilm 7200 Film Scanner
Perfection 1670 Flatbed Scanner: When I try to scan I get a message saying: "Can...
Do the following:
Uninstall the scanner from your computer
Restart
Re-install all software and drivers with the original CD * if you dont have the drivers check the manufacturars website *
Restart again
And then it should work fine. If this fails use the scanner wizard in Windows Control Panel and follow the step by step instructions.
May 18, 2010 | Epson Perfection 1670 Flatbed Scanner
How do I scan a document please?!
you can a document using a scanner.
1. you have to find a SCANNER machine that is responsible in scanning the files you want to scan.
2. Then after you find a scanner, next thing to do is to place the document file in the scanner and make sure that your scanner is properly connected and turn on.
3. Click and run the software that is bundled with the scanner to scan the document and then you have to set the path where your scanned file is to be place.
4. Then after the scanning process finished then click the save button to save the scanned files.
Thanks
Sep 15, 2009 | Office Equipment & Supplies
I can not make a scan for document .I have hp deskjet f300 series
This is usually happen when the scanner driver is now properly intalled. So rt on my computer, click on mannager ,device mannage, choose the scanner driver , click on uninstall the driver. or remover the device. restart the computer. on the scanner then your computer will search the for the driver then place the disk driver and setup the driver. i hope that your sanner will work.
May 05, 2009 | Microsoft Computers & Internet
Where is my barcode after I scan it?
Is the cradle connected to the pc via either usb, serial or keyboard wedge?
If so you will need to first, pair the scanner with the cradle by scanning the barcode on the cradle and second, configure the cradle properly so it transmits the data to the host.
Download the product reference guide from motorola website. You will get all the configuration information you need in there.
Mar 20, 2009 | Symbol LS3578-FZ Barcode Scanner - P/N...
Scanner is making lines why?
It Usually Indicates The Scanner Door Is Not Seating Properly Try To Scan Something With Two Sheets Of Paper Behind It. If That Doesn't Work Try Placing Your Hand On Top Of The Scanner And Press Down Lightly While It Scans. Please Let Me Know Your Results.
Jan 19, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
AR-M280N Scanner's product key vanished into thin air
Trial scan was probably enabled in simulation mode. This allows 500 free scans to be done but needs no product key. This is turned on in sim 26
Mar 20, 2008 | Sharp AR-M280N Copier
Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Mar 05, 2008 | Epson Perfection 3490 PHOTO Flatbed...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
