Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
On my screen in front of fridge a message of ER FF
  • 1,284 Answers
Hi, this is an error code to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed. These checks require a meter and can be difficult to make, even for a technician.
Posted on May 20, 2011
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
I have a LG GR-L207DUZA ''er ff''
i dont have the manual however.. this could be your freezer fan is perhaps seized.. you can test this by leaving your freezer door open to raise the temp and wait ti see if your fan comes on.. this may take upto 10 minutes so be patient
Nov 11, 2009 | LG Refrigerators
Error code ER FF
code for defective freezer fan motor. ER FF
Sep 21, 2009 | LG LFX25960ST Stainless Steel French Door...
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
