Question about Lexmark X3350 All-In-One InkJet Printer
I want to buy x3350 black cartridge - Lexmark X3350 All-In-One InkJet Printer
  • 731 Answers
I have an Lexmark x3350 and bought a new black ink cartridge a couple weeks ago. I was working fine till now, printer screen is showing Left cartridge incorrect. I unplugged everything, tried ...
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Sep 22, 2011 | Lexmark X3350 All-In-One InkJet Printer
When printing on x3350 with a new cartridge... get lines that are double and some with thick black ink on some letters.
Try to reseat the cartridges into the printer. If problem continues, then maybe the cartridge nozzles need cleaning. Follow the simple steps below on how to clean the cartridge nozzles on the Lexmark X3350:
  1. Go to Start, Programs (Windows XP: All Programs) > Lexmark 3300 Series > Lexmark Solution Center.
  2. Click the Maintenance tab.
  3. Click Clean to fix horizontal streaks.
  4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
  5. Print the document again to verify that the print quality has improved.
Source: How to Clean the Print Cartridge Nozzles on the Lexmark X3350
Jul 13, 2011 | Lexmark X3350 All-In-One InkJet Printer
My x3350 double prints text. It will overlay each sentence on itself. When I print worksheets on excel every other vertical line will be double-printed. I've tried to uninstall and reinstall the...
This may be a cartridge misalignment issue. First try printing with the settings changed to black and white print only. If this does not work then print in fast or draft mode (this should print in a single pass with less ink. Normal or best quality is usually done by passing the cartridges over the line twice.
Run the cartridge alignment test and see if it can be correctly aligned.
It could also be that the belt that moves the cartridge holder is loose and so two passes of the print head are misaligned. This may not be repairable (at least not economically).
Feb 20, 2011 | Lexmark X3350 All-In-One InkJet Printer
I replaced a black cartridge in my x3350 and get a cartridge incorrect
if you removed the cartridge and replaced it several times, it is most likely a defective cartridge. Return it to the store where you purchased it.
Nov 03, 2009 | Lexmark X3350 All-In-One InkJet Printer
I replaced a new lexmark 23 print cartridge in my X4530 printer.
This happens from time to time. I have bought new 22 & 23 cartridges for my Lex. x3350 before with "flawed" contacts. Either return it for refund or buy a new one. Thw next working one you get, try re filling it. I get mine refilled at Walgreens. Cost for me in Texas is $10 for black and 15 for color. I refill them 4 times before I replace with new. Saved me a ton of money.
Jul 01, 2009 | Lexmark X4530 InkJet Printer
Printing cartridges are getting jammed.
Sounds like the "encoder strip" may be missing or broken. There is a little strip of plastic that runs along the length of the printer between the pulleys that move the printhead. It has lots of tiny little vertical lines on it. If this is missing, the print head does not know where it is on the page and slides wildly back and forth.
You might be able to reattach it if it is not broken.
If not, go buy an X3550 - it is a newer model that can use the same cartridges as the X3350.
May 06, 2009 | Lexmark X3350 All-In-One InkJet Printer
Ink cartridge wrong
Some times new cartridges just don't work
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
I have a X3350 Lexmark printer. I do not require color printing at any time. How can I print black only using one black cartridge only. The color cartridge is never used.
let the colour cartridge be inside the printer.if its empty then also black will print.but its necessay that the colour cartridge should be in the printer as without the colour cartridsge in the printer the circuit does not gets completed.but the cartridge should be inside the printer if its empty no problem you can just print in black it will print.
Mar 02, 2009 | Lexmark X75 All-In-One InkJet Printer
QUESTION
Facing the X3350, the black ink cartridge goes on the left, the color on the right
Dec 22, 2008 | Lexmark X3350 All-In-One InkJet Printer
Right cartridge incorrect for Lexmark X3350
checked the Lexmark knowledge base for the error message "right cartridge incorrect". It came back with instructions for the X8310/8350, X7350 and X7170. Nothing for the X3350.
http://www.lexmark.com/uncomplicate/chan...
The instructions seem to be pretty much the same for all other models so maybe they'd work for your 3350. If not, there's always the technical support link. I've got an older X1150 and tech support has always helped me out
Feb 22, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Lexmark X3350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
