When my wife puts 1/2 load or full load of clothes into the washing machine, front loading machine, the error code E10 appears on the display and the washer stops. The only way to continue is to manually go to the spin cycle. She can load the washer 1/4 load or less and the washer will wash the clothes normally. Like it did when new, Our machine is now 5 years old. Water will seep back into the drum area over 2 days or so. Does this problem have anything to do with the E10 error code or the machine stopping or the washer load needing to be reduced to 1/4 or less to get the washer to operate normally? HELP thanks
  • 157 Answers
Carbon brushes need replacing in motor
Posted on May 20, 2011
KENMORE ELITE FRONT LOAD WASHER, NO DISPLAY IS ON AND WHEN YOU PUSH THE START BUTTON IT JUST BEEPS ONCE and that is it. Thanks Craig..
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 13, 2010 | Kenmore Elite 45986 Front Load Washer
What does the code E10 mean? The washer flashes that code and won't spin.This is and Affinity front load washer.
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
Jun 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error code E10 what is it
Thank you !!
May 31, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool duet dryer-error code e-1?
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not wash clothes.
unit is taking to long to fill...check inlet hose for kink,,,check that waters pressure is up...both hot and cold,,,clean your inlet screens ,,clogged..onthejop
Feb 17, 2009 | Frigidaire ATF6000ES Front Load Washer
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
