Question about Palm Zire 31 Handheld
When i start up my zire31palm it goes to the digitizer screen. The "tap the target" keeps going and going. I continuously hit it over and over and it doesn't move on to the next screen. It works when you hit it and moves to the next target (from corner to corner). But it never gets past this screen. I have tried the soft and hard reset hold it for 30 sec and it still does not work . Any idea ?
  • Avi Auslander May 20, 2011
    The Zire31 is not being supported by Palm any more and item cannot be returned exchange I was counting on answer from you if problem can be fixed.
  • 2,069 Answers
Well you are not the first to experience such. possible solutions have been provided befor by palm staff and below is one of the extracts from their staff.
" Paul from Palm here. It sounds from your description that the calibrator is actually looping. If that's the case, you may be able to salvage the situation. It could be that a screen protector is interfering or there is dirt or debris trapped under the edge of the screen. From the Palm Knowledge Library:
If you can access the calibrator, but it loops through the target sequence (repeatedly asking you to tap the targets), there may be a physical problem that's causing your touchscreen to be confused:
* Do you use an adhesive screen protector? A screen protector which is trapped under the screen edge may interfere with touchscreen calibration. Occasionally, just having the screen protector on the screen can cause the issue. Try removing the screen protector.
* You may have debris trapped under the edge of the screen. Use the corner of a piece of thin, stiff paper (copier paper works well) to very gently slide all around the edge of the screen. Don't let the corner of the paper travel more than an eighth of an inch under the screen edge frame. By doing this, you may be able to dislodge small particles of debris trapped under the frame."
hope that helps.
Posted on May 21, 2011
  • Louis Bardugon Oct 29, 2011
    Cleaning along the edges worked, however, I did something that should be done ONLY WITH GREAT CARE! I used a vacuum cleaner with a round, soft bristled brush so as to not run the risk of exerting a strong suction on the screen. I gently pressed down on the edges of the screen with one finger and brushed the soft bristles under the edges. IT WORKED! Finding your suggestion after several days of frustrating research was GREAT. Thanks, Lou Bardugon, Hawthorne, NJ
    Novelist:
  • 89 Answers
Avia,
Sounds like a software problem. How long ago did you buy this product? I would have it swapped out if you could. There isn't much you can do from home. You need an expert to look at it. If you bring it back to the store that you bought it from, they should be happy to exchange it for you, free of charge. It is rarely the customers fault when stuff like that happens. Doesn't sound like water damage to me, so I'd be very surprised if they didn't exchange it for you. You may have to get it reconfigured if you can't exchange it. You'd have to bring it to the store you bought it from and have someone do it for you. This may cost a small charge. The good news is either one of these methods should leave you with a perfectly working Palm Zire for no charge to a very small fee. Hope this helped!
- Frankie
Posted on May 20, 2011
My Coby MP828-8G MP3 player is stuck on a blue screen sensitivity test that reads "Touch the Center of the target and hold for one second.Repeat as the target moves." I've already tried...
I cannot go back to calibrate. Even after using reset button on back of player it turns off the player but then when you turn it back on it goes right back to the blue screen again. Cannot get out of blue screen.
Jul 25, 2013 | Audio Players & Recorders
Cant align screen..help plz..show me the way..xperia x1
my phone showthn screen and masage tap the target firmly and accurately ateach location on the screen .The target will continue to move until the screen us aliged
Feb 02, 2011 | Sony Ericsson XPERIA X1 Smartphone
My htc p3400i mobile donn,t show screen only see align screen?what i do
showing align screen written in under
tap the target firmly and accurately at each location on the screen. the target will continue to move until the screen is aligned._1037.jpg
Jan 27, 2011 | Computers & Internet
I did a hard reset and I can't gt the device to go past the screen tap on the center of the target. I hit it dozens of times and it just keeps asking me to hit the center of the target
Disconnect Treo from charger, if connected.Remove the battery cover and then the battery.Press and hold the UP arrow button on the 5 way navigational key of the device.
While holding the UP arrow button, reinsert the battery.When the second screen named "Access Powered" appears, release the UP button.Then, the next screen will ask you to set the date and time. That finishes the process of Warm Reset.
Aug 24, 2010 | Palm Tungsten E2 (Multilingual) Handheld
I have an imate pda2k pocket pc and is working good. Out of curiosity i tried hard reset and it ends to align screen. Everytime i made a hard reset the screen show " tap the screen to setup your pocket pc"...
tap and hold on align target until it moves to next corner or next step, if you are using windows 6 or 6.5 you should be very much accurate on taping and holding to align the screen.
Nov 01, 2009 | i-mate PDA2k Pocket PC
Align screen on IPAQ
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
Jul 23, 2009 | Compaq iPAQ H3955 Pocket PC
Imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Oct 06, 2008 | i-mate PDA2k Pocket PC
Tapping target problem
My friends Tungsten E2 does that, he has to just keep tapping the target over and over until it procceds, thats all he can do, and it generly does go to the next screen, after a loooong while.
Aug 19, 2008 | Palm Zire 31 Handheld
RESET phone solution.. pls help..
hi,
   u just do one thing..restart ur phone again..& when it asks u to set up ur windows..than tap on the black spot firmly ...u just need to tap on than spot only..nthing else after that leave..it will start processing..& ur phone will be on.
Thanks
Gizmo1
Oct 22, 2007 | O2 Xda Trion Smartphone
Palm Zire 31 Handheld Logo
71 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
