Question about Canon i850 InkJet Photo Printer
No color printing on my i850
I ahve cleaned over and again. Removed the print head and soaked in denatured alcohol. Still no color at all???
  • hermsen668 Aug 26, 2008
    I get no printing at all. Service error 5200 appears. I think it's ink absober tank which is probably full. How to repair?
  • 1,602 Answers
ONLINE AND TYPE
CANON 850i WILL NOT PRINT IN COLOR
ROD
Posted on Feb 04, 2009
SOURCE:
My printer only prints magenta\
A color or photo cartridge is either low, clogged or has run out of one of the basic colors it mixes together to create the colors in your images. The printer cannot print correctly if it lacks one of the basic colors, even if it still contains some of the other colors. The cartridge may also be clogged. The cartridge must be replaced
This may help
You can try to clean the printer head manually. To clean the printer head, remove the ink cartridge from the printer. Moisten a cotton swab by dipping it in hot water or isopropyl alcohol, and then gently wipe the printer head. Do this repeatedly until it softens the dried ink.
For models where the printer head is located in the printer, you can put 7 to 10 drops of isopropyl alcohol in the ink receptacle where the ink flows from the cartridge to the head. Turn the printer to self-cleaning mode. You can also leave it for a few hours or overnight before repeating the self-cleaning mode.
If the print head is located in the cartridge, soak the print head in hot water and let it soak overnight. Dry the print head part using a paper towel and switch it to self-cleaning mode.
If the hot water soak does not work, place the cartridge printer head in isopropyl alcohol and let it soak overnight. Wipe off the soaked area and dry it carefully using a damp paper towel. Turn the printer to self-cleaning mode to remove any dried ink.
For more Help Source... Can You Fix Dry Ink Cartridge eHow
Thanks,
HP Phone Number
Jun 25, 2014 | HP Officejet Pro L7680 All-In-One InkJet...
Problem with printhead please consult user guide
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Mar 01, 2011 | Office Equipment & Supplies
Whereas my print cartridges are full the printer prints neither solid black or colors. I appears that the print head is plugged
Remove the cartridges and shake them to loosen the ink inside. Then soak the heads in denatured alcohol for a few seconds and wipe the excess with a "Q" tip trying not to leave any cotton lint on the heads. Then perform the clean cartridges in the printer properties.
Jan 16, 2011 | Brother MFC295CNAll-In-One InkJet Printer
I need help please, I have a Brother MFC-685CW and it does not print black. I have tried the test page, as well as many other pages (online and off) and the black doesn't print. All the cartridges are new...
sounds like the little "micron"sized hole in the PRINT HEAD is plugged. if it has a purge or clean cycle like the 465c that might work. usaully soaking in denatured alcohol is the way. i dont think the printhead is accessible to humans or mere mortals like us.
usally the instructions recommend dont turn off printer
Oct 09, 2010 | Brother MFC-685cw InkJet Printer
My printer won't print anything - only blank pages. However, both ink cartridges have ink. Please help!
If the self-cleaning cycle does not solve the problem, try turning the printer off overnight to allow the ink to soften. Turn the printer on the next day and try printing a test pattern to see whether the problem has either disappeared or become less noticeable. This ink-saving procedure can work effectively because sometimes the dried ink on the print head needs time to soften before the printer head can be cleaned completely. Try running the self-cleaning utility again one or more times.
Steps for Manually Cleaning the Printer Head
If the overnight cleaning still does not work, there may be a layer of thick ink that is blocking the holes of the printer's head. The next option is to manually clean the printer head. Follow these steps:
* Determine from the owner's manual where the print head is located.
* Remove the ink cartridge from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. NOTE: Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets, and if you get isopropyl alcohol on the gaskets it could dry them out.
* For models where the print head is in the printer, drop 7 to 10 drops of isopropyl alcohol (91% denatured isopropyl alcohol - not 'rubbing' alcohol) down the ink receptacle area where the ink actually flows from the cartridge into the head. Run a few self-cleaning utilities. If possible, allow the printer to sit a few hours or overnight and repeat the self-cleaning utility.
* If the print head is in the cartridge, soak the cartridge print head in hot water. Allow it to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
* If the hot water soak did not unclog the print head, place the cartridge printer head in isopropyl alcohol and allow it to soak overnight. Use a damp paper towel to wipe off the print head area and dry carefully. Try the self-cleaning utility again.
* If the alcohol soak did not unclog the print head in the cartridge you may need to purchase a new cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the printer head.
Jun 09, 2010 | HP DeskJet 5150 InkJet Printer
Model i9900 - All colors are not printing even though all colors are inserted and good.
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
Mar 29, 2010 | Canon Office Equipment & Supplies
I just put in a new black crt and my color ren out now it won't print at all and I have unplugged it tried to set main tab to black only canon all in one mx 300
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Mar 25, 2010 | Canon PIXMA MX300 All-in-One Printer
The color has quit working. i replace the
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Mar 07, 2010 | Canon BubbleJet i320 Printer
Black ink won't print. Color is fine.
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Hope this helps. .
Feb 07, 2010 | Lexmark JetPrinter Z25 InkJet Color...
Canon i9900 isn't printing photo magenta
Use denatured alcohol to soak the print head. Then use suction to draw the alcohol back thru to the foam ports where the ink cartridges rest. Continue until the alcohol runs clear. Then use water and then repeat with alcohol. Allow to dry and re-install in printer. Use new ink cartridges when re-starting printing.
Dec 31, 2008 | Canon i9900 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
93 people viewed this question
Clive
Clive
old marine
old marine
Ekse
