Brothers Printer MFC 7420 Error Message "Back Door Open" I opened it and closed it several times still getting message. I unpluged it andtried again. Help
  • 313 Answers
Hi. You have to follow these steps: Be very careful:
1. Open front cover, like in this image:
2. Pull out your printer's toner cartridge & drum unit:
3. Open back cover
4. Pull the tab which is in front of you in order to opBrothers Printer MFC 7420 Error - hiddenul_3.gifute cover.
5. If there is any, pull the jammed paper out of the fuser.
6.
7. Close front cover too and see if it works! If your error will still appear, try powering your printer OFF & ON
I hope I helped you!
Posted on May 20, 2011
Brother MFC 7420 printer says back cover open...close back cover, but nothing is open
hello there
try this remove the toner of the printer and put it back again and closed properly make sure door close and turn off the printer remove the power plug from the outlet and ppower cord from the printer and wait for some time and turn it back on.
thank
Mar 09, 2011 | Brother MFC 7420 All-In-One Laser Printer
Message: Back cover open. Close the back cover.
You might have to turn it off and turn it back on to reset the message. I have a Brother MFC-240C and it does the same thing.
May 30, 2010 | Brother MFC 7420 All-In-One Laser Printer
I open and close the back cover and I still get a error message back cover is open
INTERLOCK SWITCH IS NOT CLOSED LOOK FOR POSITION OF SWITCH AND MAKE SURE THAT IT IS MADE.
Mar 10, 2010 | Brother MFC 7420 All-In-One Laser Printer
Have a brother MFC 7420 multi function Machine. Keep getting signal on screen stating ''Back Door Open'' it is not have cleaned, everything suggested still same. can you help ?
The back door sensor is damaged. You could could try and close and re-close the door over and over until it registers, replace or bypass the sensor, or buy a new printer. Brothers printers are pretty cheap, depending on what your time is worth per/hour, I'd would just replace it rather than waste a lot of time.
Nov 08, 2009 | Brother Multi-Function Center MFC-240C...
Brothers MFC 7420 keeps displaying Back Door Open. Have cleaned etc. everything suggested on help websites, nothing works. Help coxmwc@aol.com
The back door is a double door. Inside the gray door is a black plastic paper guide that hinges down, also. Mounted on the inside of that is a thin, black rod, leading to a lever on your right, that swings through a slot in the side of the machine. Sometimes the lever gets bent so it doesn't fit into that curved slot. If that's your situation, gently force it back into the slot so it can block the sensor that tells it the back door is closed, and you'll be printing again.
Nov 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Showing drum error and replace toner low message all the time
Open the cartridge cover
push "option"
and push "00"
wait until the word "accept" then close the cover,
after that should be working perfectly.
May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
''Back door open, please close back door'' - back door is closed
This Error Is Reoccurring On All These Units Open Close Back Door Then Unplug For 30 Seconds And Then Plug It Back In. Check For Error.
The Brother Website Says To Check The Paper But Almost All Of These People Have Checked For Paper Problems And For Jams With No Result.
Jan 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Toner replacement on Brothers MFC 7420
Open the front cover and try to pull it out strongly.
then use the duster to clean the machine.
then you should able to replace your cartridge easily next time.
mightbe too dirty or you use ODM toner? if yes that's the problem issued from.
Nov 18, 2008 | Brother MFC-7420 Laser Printer
Back door closed
dear sir the the back door sensing switch or sensor is not working check it may be it is broken or faulty or may be it is only dusty clean it
Sep 12, 2007 | Brother MFC 7420 All-In-One Laser Printer
263 people viewed this question
jasbo
jasbo
