Question about Electronics - Others
My mp3 player won`t charge when i hook it up to the usb port on the computer.
    Problem Solver:
  • 6 Answers
Try your charger
Posted on Jun 04, 2011
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    How do you charge the delstar ds 821, & down load music?
    MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
    You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
    Mar 08, 2012 | Audio Players & Recorders
    The battery is not charging
    You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
    Some things to check for when your player does not act like its taking a charge.
    USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
    Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
    USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
    Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
    Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
    AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
    I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
    SanDisk Mp3 Player Frozen
    Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
    My sansa cannot be detected by a computer as a drive but it charges when connected to a PC
    try installing the sandisk software, if it is installed, try hooking it to a different usb port, or uninstall the software and just hook it to a usb port and see if windows will detect it
    Nov 18, 2009 | SanDisk Sansa Fuze MP3 Player
    Charging:
    Fixed. I happened that the usb port that I was trying to charge the unit on was not a fully active port. So I moved it to another cpu. Problem solved.
    Thanks
    PK.
    Jun 10, 2009 | Audio Players & Recorders
    My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
    This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
    Make sure that the USB cable is properly plugged in and use the original cable.
    Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
    Battery
    Latest firmware
    Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
    I hope this helps, and don't forget to rate the answer.
    Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
    Sansa clip wont power up unless hooked up to usb
    http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
    Windows XP SP2
    • Windows Media Player v10
    • Intel Pentium class PC or higher
    • CD-ROM drive
    • USB 2.0 port for hi-speed transfers and charging
    Make sure HOLD button is not on.
    Battery
    The Sansa
    Clip player comes with an internal rechargeable battery. To use the player for
    the very first time, remember to fully charge the battery. You can charge your Sansa
    player through the USB port of your computer, a car adapter (not included) USB port, or AC
    adapter (not included) USB port.
    Charging
    To charge the battery, please follow these steps:
    1. Connect the larger end of the USB cable into an available USB port on the
    computer.
    2. Connect the smaller end of the USB cable into the Sansa
    Clip player.
    3. The computer must be on for most USB ports to charge your battery. Your
    Sansa
    will show connected and the yellow charging indicator will appear.
    The battery level indicator will blink while charging. You will not be able to
    play while connected to the computer USB.
    4. To stop recharging, simply disconnect the cable.
    The battery can also be charged using an AC adapter (not included) or a car adapter
    (not included) and you will be able to play your device while charging with one of the
    adapters.
    NOTE: Some low-power USB ports may not be able to provide enough charge
    power. Also note that the rechargeable batteries are not replaceable.
    Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
    Mp3 insignia sport
    is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
    if no hub try a different usb port or a different cable
    Aug 10, 2008 | Insignia NS-DV2G MP3 Player
    I have an coby mp3 player model num:mp.c7085 i connected it to the pc to chage but it doesn't light up to showit is charging. what can i do?
    Some of the computer FRONT usb ports only transfer signals but don't provide power. Try hooking your player to one of the REAR usb ports and see if it charges.
    Jun 21, 2008 | Audio Players & Recorders
    Noggin
    the player has to be connected to computer via USB cord one end goes into the mp3 or mp4 and the other goes into the usb port after it has charged to turn it on u have to hold the menu button down/ Thats how mine work Does anyone know how to add videos I have added pictures which looks beautiful.
    Feb 19, 2008 | iLO (2 GB) MP3 Player
    Electronics - Others Logo
    63 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
