Question about Refrigerators
Freezer frosts over and blocks the flow of air throughout the refrigerator and causes it to warm up inside.
    Scholar:
  • 99 Answers
If this condition just started happening, and you haven't changed the setting or overstuffed the fridge, it may be your defrost timer. With the compressor running, turn the screw on your timer until you hear a click and the compressor shuts off. The compressor should come back on in 20-30 minutes. If this doesn't restore the normal operation, or if it fails to defrost again, you'll need to replace the timer. This only works for mechanical timers and not solid state timers.
Posted on Aug 14, 2008
New frigidaire refrigerator frost in back of freezer
Is it on the inside or outside of the freezer? I assume inside.
Be sure the air flow from the fan is not blocked.
Oct 03, 2012 | Frigidaire Refrigerators
Refrigerator is to warm,freezer to cold model is ed5ghexnloosso649995
In most cases something has blocked the vent from the freezer. Sometimes you catch this at a point that the freezer seems too cold but just what may be happening is the ADC control has failed causing the evaporator to freeze over with frost blocking air flow to the fresh food section. The ADC is Adaptive Defrost Control and can be forund here=> ED5GHEXNL00 Fresh Food Section Controls in that photo location 6 is the ADC or defrost control board=> W10353224 Defrost Control Board If you disconnect refrigerator from power source and lower control panel you can look this board over on both sides. Sometimes you will see burn marks or signs of heat damage, not always.
Second most Likely is the defrost heater behind the rear wall of your freezer=> ED5GHEXNL00 Unit Parts and in that photo part location 33 is the=> 2188175 Defrost Heater Assembly
Ways to test this heater are on same page. Then we always need to consider the defrost thermostat found here=> ED5GHEXNL00 Air Flow Parts item 6 in that photo. At -5 to +5 degrees the contacts inside should be closed and once the freezer goes into defrost the defrost thermostat opens its contacts at 50 degrees to prevent extended defrost. Part Number=> 2321799 Look inside rear of the freezer and if a layer of frost is building on rear wall then you most likely have a defrost problem causing the freezer to be colder. If fan in freezer is working properly then you should have a steady stream of cold air flowing to the fresh food compartment. Let me know just what you find so I may assist you in the repair, Thanks, Sea Breeze
Sep 22, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer gets cold, but nor refrigerator section.
A lot of times when a freezer works but the refrig. section is warm its a problem of it not automatically defrosting so its builds up frost in the freezer so much so it restricts air flow into the fresh food section because the freezer coil is one big block of frost and no air can flow through it. THis tip i wrote covers the components of the defrost system and how to check them.
http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Sep 09, 2011 | Kenmore Side by Side Refrigerator
The freezer is cold, the fridge is warm, and the fan in the back of the freezer is running.
Ya got 2 possible thing that will cause that
1) the damper in the upper left corner of the refrig.compartment is stuck closed so no cold air can enter from the freezer into the fresh food compartment,by placing your up to that damper their should be some (not a lot) of air flowing through it. If not it is stuck closed
2) its not defrosting in the freezer so the freezer coil where all cold air is made is totally one huge block of frost again causing air flow into the fresh food compartment to be cut off.Do you see frost build up on the back wall of the freezer?? if so this link describes what to check http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Aug 27, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
My freezer is freezing like it should. The fridge however is warm. What would be the problem?
Be sure there's no excessive frost on it cause it may weaken cold air flow around.
Also do not load your fridge with too many unnecessary food stuff.
Arrange food stuff in order and do not block those air vent flowing that will hindrance flow.
Check if the fan is running smoothly.
Thanks, it's a pleasure to help you.
Jul 01, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Hello! Help the fridge side is not cooling ( warm)the freezer is fine???
Hi patsilke,
This complaint is usually the result of a defrost problem. The first thing to check in this case is the freezer area. Look at the back panel inside the freezer. If you notice frost covering the back panel, you have defrost problem. What happens when you have a malfunction in the defrost system is the air cannot circulate from the freezer to the fresh food section. Also, excess frost builds up within the coils inside the freezer. This is what is blocking the air flow to the fresh food section.
Hope it helps.
Thank you for using FixYa.
Apr 03, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
The motor is running, but the freezer is just cool and the ref. is warm. Some osf the lights are on and some are not.
The cooling coils for both the freezer and fresh food sections takes place in the freezer behind the panel. The fan in the freezer blows the air throughout the freezer and into the fresh food side.
First check to make sure the fan is running inside the freezer, you will be able to hear it when you open the freezer door. Then check to make sure the fan on the outside is running. You can tell by pulling off the grille on the bottom front of the refrigerator and feeling air come out on the left side, it should be warm air and not too hot.
If these are okay then look in the freezer behind the food and shelves. Near the bottom of the freezer look for a frost build up on the back panel. If there is a frost build up then you have a defrost problem. If you see a little frost on the panel that means there is a lot behind the panel that is blocking the cool air from flowing.
Let me know what you see and I will help you from there.
Phil
Jun 21, 2010 | KitchenAid Refrigerators
The refrigerator on my SubZero 650 is too warm. I set 38 F and the indicator goes directly to 48/50 degrees within a second of me releasing the temp select button. Freezer works fine. I have cleaned the...
I believe it's showing the actual temperature that it's currently inside the refrigerator, not the temperature it's set at. At least that's how my sub zero works. You may need to clean the coils to get it to cool better.
Apr 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
I have a Jenn-Air JCD2389G Side by Side Refrigerator. The bottom of the freezer keeps things frozen, though the top of freezer & refrigerator remain mild to warm. There is not an excessive amount of...
It sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
Apr 25, 2010 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
