Question about Hitachi 50V500 50 in. HD-Ready LCD Television
My hitachi 50'' lcd tv shuts off and turns on automatically after a few seconds
  • 373 Answers
Problem could be the thermal fuse cutoff on top of the lamp assembly. Has two wires going to it. A good test is to remove one wire and connect an alligator jumper to the two wires by passing the thermal fuse cutoff and see if it will stay on. Clean out any dust in the chassis as it can cause overheating. Do not leave the set hooked up this way permanently! Just to test!
Posted on May 20, 2011
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
TV displays RGB code and then displays, no signal and then shuts off. What does the RGB code mean?
It means the source is not set correctly. Switch the source to input 0 (cable or antenna depending on your particular set up).
http://www.vizio.com/l32hdtv10a.html#support
Will lead you to the manual and quick start information if you need more specific instruction.
Joe
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
Temp light flashes tried unplugging it for a few minutes turned it on tries to power up but then power , lamp , temp lights flash for a few seconds then it shuts down and temp light stays on
It sounds like you have a thermal issue. The TV is getting too hot or the Thermal Fuse is bad. The thermal fuse detects the temperature in the TV and tells the TV to shut down if it thinks it is too hot. Most likely caused by poor ventilation or clogged fans from household dust. Try moving TV away from wall or cabinet first, if this does not fix the problem, clean ALL the fans in the TV. If problem still persists, replace the thermal fuse.
Oct 04, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Power shuts off after only a few seconds, unplug doesn't reset!
panasonic tv model tx-51p800x,return to standby mode after few seconds,have already replace a new power board.
Apr 10, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Sony lcd projection tv repeatedly turning on & off
There are 2 primary things that can cause this problem - a bad TEMP sensor that is sensing too much heat, OR, a lamp that is going bad, which sometimes causes excessive heat before it dies. Either way, the set will shut itself off, and you can turn it back on in about 5 min or so, and it will work OK....for another period of time before it shuts off again.
You need a good TV Tech with the Sony Service Codes for your set, to come out & check your set. The Service Codes will tell him the exact problem you are having, and how many hours your set has been running. Most of the time a new bulb solves this problem, (if youe set is at least 3 years old).
Jan 17, 2009 | Hitachi 43UWX10B 43" Rear Projection...
TH ETV TURN OFF ITSELF
the cooling fan could be going out
Dec 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
50V500A
if the lamp has dies alot of the time to can look inside the lamp and see if it exploded (not always) do you get blinking lights?
Feb 01, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi TV problem
Question: Is complete power going off and on or just the video?
Dec 14, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
100 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
