When i try to turn on my soundbar hts8140 it pops up with low pwr / standby (freezes) and turns automatically off.
  • martin skaaning May 20, 2011
    I still have warranty on it, so I will just get it to the vendor.... thx for the fast reply.
    I will take it to the vendor as I got warranty on it... nice and fast reply. tyvm.
    /martin
  • 2,098 Answers
Hi Martin,
This is an indication of faulty power supply. The output of this section gone to out-of-regulation condition which is commonly caused of faulty filter electrolytic capacitor in the output of this stage. It will dropped the normal working voltage and will disable the unit. The processor can't initialize once there's a problem with the supply.
Another reason of this symptoms is still in the power supply. It has a multiple output voltages and if one of this voltages gone, the unit will not power up. This was caused by open fusible resistor, shorted transistor, shorted zener diode.
Also, consider bad solder joints in this section because it will do the same symptoms. Cracked, dried, cold solder will produced an out-of-regulation condition.
Let me know if your handy with electronics and I will guide you fixing the unit.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to send the unit to your local Philips service center to isolate the faulty parts.
Check also if your unit is still under warranty/extended warranty, avail it because the manufacturer will fix it for free. Don't attempt to open the cover, it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 20, 2011
  • Jdvillanueva
    Jdvillanueva May 20, 2011
    Thanks for the response, that is the best and wise decision on your part.
    Again have a nice day and thanks for using Fixya.
When I turn my tv off, do I have to turn off the vizio soundbars or can I leave it on.
Eco Power On/Off Eco Power On: Eco Power Off: Press the Next/Previous button to enable/disable Eco Power Mode. When enabled (On), the Sound Bar will go into standby after a period of inactivity. The sound bar will automatically turn off when no audio signal is detected. Off disables this feature. Note: Enable this function if using a TV remote to control the sound bar.
http://cdn.vizio.com/documents/downloads/accessories/S4221W-C4/QSG_S4221WC4.pdf
Jun 30, 2016 | Vizio VSB210WS Soundbar
Standby mode
If you have your soundbar connected via HDMI, look for an option to disable the link between your TV and your soundbar (when this option is on on the devices connected toghether, when you turn off/on any of them automatically does to the same with all devices).
Nov 21, 2013 | Boston Acoustics TVee Model 30 Soundbar...
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I dont know how to turn it on.... it has no power button
There is really no power button only OPTION/PWR OFF button of your player.
If you press and hold the OPTION/PWR OFF button, the screen turns off and the player enters standby mode.
If you press any button while the player is in standby mode, the "Now Playing" screen, etc., appears
and the player is ready for operation. Furthermore, if you leave the player in standby mode for about 4 hours,the player turns completely off automatically.
If you press any button when the player is turned off, the start up screen appears first, then the "Now Playing" screen appears.
Thanks.
gylacz
Aug 28, 2011 | Sony NWZ-E438F Digital Media Player
Some DVD's dont work on my DVD player??!!
This worked for me (taken from the service manual)
Power on Unit Select Disc Then Open / Eject Then type the following...
9999 followed by *subtitle* followed by the region you want EG: Region 2 would be - 9999 *subtitle* 2
Works perfect for me :)
Mar 12, 2010 | Philips SoundBar DVD Home Theater with...
My soundbar (Phillips hts8100) freezes on low pwr standby.
hi
i have also same problem, by that time i am pressing tv/ disc button then it should be okay
Oct 11, 2009 | Philips SoundBar DVD Home Theater with...
Reset my soundbar
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
Aug 12, 2009 | Philips SoundBar DVD Home Theater with...
Codes to make philips soundbar hts 8140/75 mulitzone
I followed another post which is a generic code for all philips dvd players. open the dvd drawer, push 9.9.9.0, close drawer. done! terrific
Jun 05, 2009 | Philips DVP5990 DVD Player
Need to multi region Phillips Soundbar
HI Ian,
Have also just purchased a Philips HTS8140 with Philips LCD screen.
Found a result on web as follows:
1.Turn on TV
2.Turn on Sound Bar System.
3.Press eject.
4.Press 9 9 9 0 (0 being Region Free or place the desired region #)
(a message displaying "region 0",or the region you chose, will appear on the screen.)
5.Switch soundbar off to soundby.
6.Turn player back on and it should be either region free or the region you selected.
So far I have not been able to check with anyother disc exept region 4.
Hope this is of help for you!
Xtopher
Jan 10, 2009 | Philips SoundBar DVD Home Theater with...
Dvd unlocking for brand new Philips Soundbar HTS6100
Figured it out unlock for HTS6100, it's the same as for HTS8100
1. Turn on
2. Press Eject
3. Press 9, 9, 9, 9, 0
4. Swtich it to standby
5. Turn the player back on & it should now be region free.
Jan 04, 2009 | Philips Code Free DVD Player
63 people viewed this question
 Grubhead
Grubhead
