Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Kenmore coldspot 106.56566400 ice dispenser not working
Recently I had the start solenoid replaced on my fridge due to power outages and after I had it fixed and my ice maker has started working again the dispenser doesn't work. I had tried changing from crushed to cubed to free the auger but it does nothing. I am not sure if the motor is bad or it is just frozen up badly. Any tips you have would be great. Thanks in advance.
  • Neil Wheeler
    Neil Wheeler Apr 23, 2009
    Sorry for the long delay I wasn't getting emails from this site. I will try your suggestions and see what happens.
  • Kenmore Master
  • 5,568 Answers
I don't know whether your power came back without surges or not but as marginal as our stuff is designed, it wouldn't surprise me to learn that the drive motor for the dispenser took a hit.
Our Kenmore ( by Whirlpool - a company I would avoid if it was possible) will allow the drive motor for the dispenser to run with the bin pulled out and it can be clearly heard running if it isn't being overshadowed by the crushing and rumbling of the ice cubes.
Examining the motor housing, it appears to be easy enough to remove so it could fall in the DIY range.
If you remove it, check to see if it is possibly individually fused; I doubt it but have not had mine apart.
It shouldn't be necessary to tell you but I don't know you either -
PULL THE AC PLUG!
If you are in the US, check your phone book or look on line ( http://www.johnstonesupply.com/corp/Default.aspx ) for Johnstone Supply in your area. It calls itself 'wholesale' but I have bought from them for years and their pricing is waaay below what dealers will charge.
Typically, when I do a parts search, their prices are 50% or more below dealer prices.
Posted on Sep 01, 2008
2 Suggested Answers
  • 93 Answers
SOURCE: Ice dispenser will only give crushed ice; will not
Your selector solenoid is not working. Next to the auger motor there is a selector. You will see a plastic peice in a hole to the left of the auger.....Try to move it up and down. If it won't move it is more than likely frozen in one spot. Try to defrost it. If that does not work then replace the solenoid.
Posted on Sep 13, 2009
Kenmore coldspot refrigerator model 52552100 makes ice but wont dispense it
Below is a fix by another owner of your make and model for the same issue.
Pulled out ice bucket; tried ice dispenser with door latch pressed in and solenoid engaged and motor moved. Tried again and nothing (couple of times). Tried water...all good...good closure of dispensor flap (air pot operated). Opened dispenser (pried off carefully from bottom on this unit not to take off the glued part) and saw the micro-switch broken off of the ice dispenser side. Checked micro-switch (all good). Replaced control bracket...all good to go.
Nov 25, 2016 | Kenmore Refrigerators
Kenmore coldspot ice maker not working
check to make sure the water hasn't frozen in the tube that it should fill the tray with. Please let me know if this isn't the problem and I can further assist you. If frozen, you should thaw out the freezer to get it working again.
Good luck
Apr 11, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
LG LFX25976ST refrigerator water in door but no water to ice maker
Check for 120 V at valve when it is supposed to be filling
Apr 01, 2013 | U-Line Refrigerator Ice Maker
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
Aug 22, 2017 | Refrigerators
HAVE A KENMORE FRIDGE M.#106.74253400 WATER DESPENSOR STOPPED WORKING AN CAN HEAR IT HUMMING AN ALSO THE ICE MAKER WORKS SO I NO ITS GETTING WATER? THANKS
my kenmore did the same thing, It had a duel water solenoid on it and one that let water into the door water dispenser went bad. also my ice cube started to get smaller, the rubber in the other side of the water solenoid was dry rotting and eventually ruined the ice maker. I replaced the duel solenoid and ice maker and had no more problems.The solenoid is on the back of the fridge, it is what the main water supply connects to.
Dec 31, 2011 | Refrigerators
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
My GE side by side fridge doesn't dispense water.
When you press the handle, do you hear/feel a click?
Is this just starting to happen after a power outage?
Is the ice machine making ice? Dispensing?
Do you have/know how to use a multimeter to check voltages at the water valve solenoid?
Thanks!
Feb 21, 2010 | GE (ESS25KSTSS) Side by Side Refrigerator
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
1,465 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
