Question about Canon imageRUNNER 2270 Copier
Hello Sir, Please help me out this problem. I have canon copier IR2270 and it have problem paper jam i tried so many times to clean all rollers and all accessories. Ones paper out the copier its get jam all time....if you can help me i really appreciated.
  • 106 Answers
1. Check paper size settings
2. Check paper exit sensor (after the fuser unit)
Posted on May 20, 2011
Canon IR8070 paper jam infront of Registration roller
If you can reach the paper in the jam you will have to pull it out to dislodge the jam. Be careful not to rip the paper in doing so!
Aug 28, 2014 | Canon Office Equipment & Supplies
Sir in our office the canon ir2270 jam the papers. plz send me the steps which we handle this problem
Please follow these instructions every time you load paper and you will never have paper jamming problems.
Make sure that the paper drawer is properly in place. Do not load paper of an irregular size into the paper drawers. Do not load the following types of paper into the paper drawers. Doing so may cause a paper jam. - Severely curled or wrinkled paper - Thin straw paper - Transparencies - Paper which has been printed on using a thermal transfer printer (Do not print on the reverse side of this paper either.) Fan the stack of paper well before loading it. Never place paper or any other items in the empty part of the drawer next to the paper stack. Doing so may cause paper jams.
Also to clear paper jam if you have the manual with you follow it OR you can go to this link and download the manual. It is equally applicable ti ir2270
http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Sep 13, 2011 | Office Equipment & Supplies
Printer is working sir but paper is jammed i need help. recently i refilled toner, after this toner filling paper jamming coterminously please help me
If this is the first time you have refilled the toner I would guess the Toner is the wrong type, has leaked out and is causing the paper to stick to the rollers. The only way I know of effectively cleaning this is to pull the rollers out, which involves pulling most of the printer apart. Its not a easy job.
Apr 05, 2011 | Canon LASER SHOT LBP-2900 Printer
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
Can not get the copier to pull paper from the top draw with out jamming each time.
first, pull out the top drawer and open the right lower cover and door. now if you look into the "hole" where was drawer, on right side you will see the 3 rollers that pick, feed and separates the paper.
Remove all rollers and clean them with alcohol and dry them out, or change the places with rollers from lower drawer. Also when the right door are opened you will se two axis with two rubber rollers, clean them very well.
The iR2270 has issues with pressure on lower right cover and you need to put the rubber or similar in wide and narrow slot on lower cover, so that when its closed presses the inner paper guide which touches the rollers on axis. If You already have metal "wings" on lower cover, you don't need to apply any additional pressure.
But necessarily change the roller for paper of both cassete's and in fixing unit the fixing cleaning roller.
Hope that helps!
Mar 22, 2011 | Canon imageRUNNER 2270 Copier
Dear sir, I have a 4 IR 5000 machine. One machine complaint is paper jam, the paper jam err code is 0102. how can solve the problem please reply immediately
This means that there is a delay jam on the second sensor from the paper casette. You will have have to replace the pickup rollers, or try cleaning them.
Dec 21, 2010 | Canon imageRUNNER 5000 Copier
Paper keeps jamming. Now it has a small piece of paper stuck in machine. Any help besides serviceing?
Sir, were does the paper jam? we need to remove that paper. and try to clean the feed rollers with wet cloth with water or alcohol then try it.
Feb 24, 2010 | Canon imageRUNNER 210S Copier
My canon imageclass mf4270 jams 90% of the time when i try to print. sometimes if i pull out the toner cart several times. it will print.
Hello sir; Check the paper path carefully is there have anything block over there, especial at both end. is the paper jam everytime at same place? cleaning up the roller with alcohol.
Aug 05, 2009 | Canon Office Equipment & Supplies
Canon 5870 PAPER JAMS
Hello sir; You have to clean roller with rubber rejuvenator( get it from stationery store) then willtake care your problem,good luck.
Jan 08, 2009 | Office Equipment & Supplies
Canon imageRUNNER 2270 Copier Logo
297 people viewed this question
old marine
old marine
