Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Most likely there is some blockage in the drain filter or the drain hose. I am assuming you are able to hear the drain pump operate at the right time in the wash cycle.
The parts involved are shown in this diagram.
Posted on May 20, 2011
If your unit has a fine screen filter at the back/bottom of the tub then it could be a piston and nut problem. Remove the screen filter assembly and the piston and nut. It unscrews from the floor of the tub. Check that it is sealing correctly.
If this assembly does not seal correctly then draining will be difficulty or wont drain .
If you liked my answer,kindly don't forget to rate it
Thanks
Feb 08, 2016 | Belling 24 in. IDW603 Built-in Dishwasher
Jan 17, 2016 | KitchenAid Dishwashers
Dec 12, 2015 | Kenmore Dishwashers
Apr 21, 2015 | Samsung Dishwashers
Jul 22, 2013 | Dishwashers
Oct 16, 2012 | Whirlpool Dishwashers
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn
Oct 20, 2010 | Jenn-Air 24 in. JDB2100AWS Built-in...
May 15, 2010 | GE 24 in. Profile PDW7800 Built-in...
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
100 people viewed this question
