Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan Logo
Posted on May 20, 2011
I am trying to move my Hunter 60" regalia ceiling fan from one room to another but I can't figure out how to remove it from the ceiling
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
2418
Points
10
If you look at the piece that nudges up to the ceiling, there should be some screws somewhere near the very top, right by the ceiling. If they are there, unscrew them and you should be able to figure out how to twist it to remove it. If the screws are not there, try twisting the piece at the ceiling counterclockwise, sometimes its got some catches and you just turn it to kind of set it in place. If this is the case, you should be able to just twist it and it should drop. Either way (by the way, those are the only 2 ways it is possibly held on), once that part is done, you simply lift up on the fan to remove it from the ceiling bracket, unscrew the wirenuts (WITH THE POWER OFF), and remove the ceiling bracket. Then all you do is reverse the process for where you want to put it up. The wires are color coded-black from the ceiling to blue or red on the fan. White from ceiling to white on fan. And the green to the green. Good luck.
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Designers Choice Ceiling Fan Manual
All Hunter fan model numbers are 5 digit and start with a 2. Are you having a problem with the fan?
2answers
3answers
Hunter ceiling fan model 23530-300
the roll was rusted maybe .you can take apart it for checking .
ceiling light
1helpful
2answers
Where can I get a new motor for my Hunter Designer's Choice Ceiling Fan (model # 99048
Call Hunter at 1-901-745-9222. I think this number is still current, it might not be. Tell them your issue, most likely they will send you an entire new unit (or is your fan the OLD Designer's Choice from the 80's with a rubber flywheel?)
Need installation instructions for a Hunter Regalia ceiling fan, model 28642, item 183013, as the fan came without any. Am ready to install now!
Robin - Here's a link to the Owners Manual for the Model Number Hunter Ceiling Fan, you listed.
You may download and print it for future reference.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/45065.pdf
Please don't forget to leave me a rating for helping you. Thanks!
2helpful
2answers
Do you know where is Hunter fan's fuse?
There are several portions for a ceiling fan... it sounds as if the small motor that actually turns the blades shorted / or burned out.
Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Btw, Iā€™m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Top Hunter Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
