Question about HP PhotoSmart 7960 InkJet Printer
Cannot find the door or where to replace the cartridge ?
  • 106 Answers
Watch from 1:00
Posted on May 20, 2011
Printer HP 1315 shows "Door Open" and does not respond to printing call
This is a more common occurrence than you might expect. The "door" referred to in the error message is actually the portion of your machine that must be lifted up in order to gain access to the ink cartridges for replacing them. You will notice that a protrusion on the lower side of the "door" surface fits into an opening in the surface below the door when the door closes, and this contacts with the door status switch to close the contacts on the switch, telling the machine that the "door" is closed. If indeed the door is fully closed, with nothing obstructing the switch from performing, then that would indicate that either the switch is defective or has come loose. After replacing cartridges, the "door" must be fully closed or you will see the error message. For troubleshooting procedures to solve this problem, go to this link: http://support.hp.com/us-en/document/c00829896
A test print page may show distorted characters at the beginning, but the characters should be shown correctly towards the end of the test page. If this is not the case then I would suspect that at least one of your cartridges is not seated properly. Open the cartridge access "door," and check the cartridge positions. When you remove and replace a cartridge, the new cartridge should be pushed back as far as it will go and then the front end of the cartridge lifted until you hear it snap into place. When seated properly, the top of the cartridge will be level.
Feb 11, 2015 | HP PSC 1315 All-In-One InkJet Printer
How to remove and insert catridge on right
Switch on printer, wait up to initialize, lift cartridge access door located at right side of the printer(check snap shot)wait till cartridges stayed at right side,gently push cartridge down wards to un lock, take out cartridge, replace desired cartridge..close the door & check display for ready mode...Note: Used cartridges & refilled cartridges may give error message to replace it.. If you are replacing with new one, printer will print align page to align cartridge.. For aligning the cartridge put printed paper in face down condition in scanner & scan it.. 5_25_2012_7_00_52_pm.jpg
May 25, 2012 | HP Officejet 4355 All-In-One InkJet...
Problem : 10.92.00 cartridges not engaged. The front door do not close probably I removed all cartridges the front door closed and the printers worked. Reinstalling the cartridges failed with same error...
10.92.00 The Black print cartridge are not engaged correctly.
? Open and then close the front door.
? If the message persists, make sure all the print cartridges are seated correctly.
? Clean the contacts on the memorycontroller PCA.
? Make sure that connectors J302, J303, J304, and J305 on the memorycontroller PCA are seated correctly. Also make sure that connector J1020 on the DC controller is seated correctly.
? Replace the memory-controller PCA if it is damaged.
? Check the gears on the print-cartridge drive motors. Replace defective motors.
? Replace the DC controller.
Aug 10, 2011 | HP LaserJet 3600n Printer
How do i install a new cartridge
Welcome to FixYa!
Toner cartridge replacement for HP LaserJet 3055.
Press the cartridge-door release to open the print-cartridge door.
Remove the print cartridge from its packaging, and then rock the cartridge gently five or six times.
Bend the plastic tab at the end of the cartridge.
Pull the tab until all of the sealing tape is removed from the cartridge.
Hold the print cartridge by the handle and insert it into the all-in-one and then close the print cartridge door.
I hope this helps.
Thank you for using FixYa!
Jas247
Apr 02, 2011 | HP LaserJet 3055 Printer
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
10.92.03 error showing while printer door closed.
One of the cartridges may not be seated correctly. Open the door and remove all the cartridges. Close the door and power the printer on. Then, replace each toner one at a time, closing the door in between each one. This should allow you to determine which toner is not seated correctly. Remove and reseat that cartridge. Clear any foreign debris from the area. You may have to replace that cartridge in the event it is defective.
Nov 11, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Maintenance cartridge
Also turn off the machine pull out the old one then put back the new one. Don't forget to replace the shaft cleaner also.
Apr 01, 2009 | Canon imagePROGRAF iPF8000 Printer
How to load the new ink cartridge. HP Photosmart C5140.
Replace the ink cartridges (from the manual for the printer)
Follow these instructions when you need to replace ink cartridges.
To replace the ink cartridges
1. Make sure the HP All-in-One is turned on.
2. Open the ink cartridge door by lifting from the front center of the device, until the door locks into place.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch. If you are replacing the black ink cartridge, lift the latch on the far left.
If you are replacing one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot. Make sure that you insert the ink cartridge into the slot that has the same shaped icon and color as the one you are installing.
6. Press down on the gray latch until it clicks into place.
7. Repeat steps 2 through 5 for each ink cartridge you are replacing.
8. Close the ink cartridge door.
Jul 04, 2008 | HP Office Equipment & Supplies
HP PhotoSmart 7960 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
