My samsung air conditioner AQ12FEN is not responding to the remote control i think its lost its memory because all three light indicators are flashing but it give out a sound when i switch it on but nothing happens. am told they are reset codes to bring back its memory please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bobotfel
  • 236 Answers
SOURCE: air conditioner
Some some remote control have RST or RESET button, you have to push this every time you change the battery or for malfunction remote control. You can find this either in front of remote control or at the back of the remote in battery compartment.
Posted on Jan 01, 2008
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
  • 215 Answers
SOURCE: how to repair Samsung AQV 12 FAN Air Conditioner
You can turn off the Thermostat, and the powers switch on the furnance and turn the breaker off in the breaker box wait about 20 - 30 minutes and turn the breaker back on, and the power to the furance back on and the thermostat, this should reset the system.
Melvin
St Louis
Posted on Oct 04, 2009
co7196
  • 3433 Answers
SOURCE: Samsung Air Conditioner will not turn back on after power Outage
Turn off the circuit breaker and wait 10 mins, then back on.
Turn off all units, wait a about 1/2 hr. See what that does. Also, Turn only one unit on at a time and let it run 5 min before turning on the secon and the same withe third. An what remote island might that be? Good Luck, Ned
Posted on Nov 11, 2009
  • 1150 Answers
SOURCE: reset air conditioner samsung aqv12msan
http://nodevice.com/user_manual/samsung/other4/aqv12msan.html
Go to this web site. It has a copy of a user manual. May get the answer to your question as to how to reset.
Hope this does it for you.
Posted on Dec 03, 2009
Hitachi A/C. The green light of air filter indicator is on.
When its turn off, not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
Aug 10, 2012 | Hitachi RAS-09UH Air Conditioner
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
First green light light blinking continiously when switch on,no respond when press any remote control button's,indoor cannot start at all
dear sir
i think its an micro controlling unit problem for solve this problem please make air conditioner,s main supply switch turn off and after two minutes again turn on for reset of micro controller system . i hope after that it will work .
hope answer the question
thank you
please vote!
Oct 02, 2010 | Heating & Cooling
I´V LOST MY REMOTE CONTROL FOR AW1293L SAMSUNG A/C
Most of the refrigeration supply shops have them approx $50.00 aust
Mar 29, 2009 | Samsung AW1293L Air Conditioner
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Samsung AS12ABMC A/C (about 3 years old)
heres a clever way i use to check remotes are working. put your mobile phone into camera mode and point your remote control toward the camera while pressing any button.if working you will see a blue light emiting from your remote on phone screen.
Jul 08, 2008 | Samsung AS18A6RB Air Conditioner
Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Jun 05, 2007 | LG LSC121PMA Split System Air Conditioner
What do I have to do?
Introduction Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are programming into the remote. While some trial and error may be required to get the right codes input to control your equipment, the pleasure at getting rid of several extra remote controls will far outweigh the hassle in getting it programmed. Instructions Difficulty: Easy Steps 1Step OneManually turn on the device you wish to program. 2Step TwoPress the Code Search button on the remote until the indicator light turns on. 3Step ThreeRelease the Code Search button. 4Step FourPress and release the button for the device you are programming. 5Step FiveEnter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. 6Step SixAim the remote at the device and press the power button. The device should turn off. 7Step SevenPress Channel Up on the remote with the device on. If the device responds, no further programming is required. 8Step EightTo look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator SAMSUNG 002 012 102 103 112 212 502 512 818 914
Apr 01, 2007 | GE RM24911 Remote Control
Heating & Cooling Logo
185 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
