Question about Cannondale Jekyll 1000
I have a 2001 model and have never changed the bearings on the lefty hub. When I noticed the wheel was loose and took it off the spindle pieces of the large bearing mounted near the brake disc fell out and I was able to pry out the rest but I don't know where the smaller bearing goes or how to take it out. Can you help? Thanks
    Brigadier General:
  • 8,546 Answers
  • mgraffis May 20, 2011
    I figured it out right after asking, duh :) Thanks though!
I've changed rotors before but never on a 4 wheel drive. Could you tell me how to on a 1989 ford ranger?
Brake Rotor (Disc) - REMOVAL & INSTALLATION
  1. Loosen the wheel lug nuts.
  2. Jack up the front of the vehicle and support on jackstands.
  3. Remove the wheel and tire.
  4. Remove the brake caliper assembly as described earlier in this section, but do not disconnect the brake hose.
  5. Suspend the caliper assembly by a piece of wire. Do not allow it to hang by the brake hose.
  6. Follow the procedure given under wheel bearing removal in Suspension and Steering for models with manual and automatic locking hubs (lines down).
New rotor assemblies come protected with an anti-rust coating which should be removed with denatured alcohol or degreaser. New hubs must be packed with EP wheel bearing grease.
  1. Installation is the reverse of the removal procedure.
Front Wheel Bearings - REMOVAL & INSTALLATION
(see Figure 1 )
Fig. 1: Inspect the bearings for abnormal wear and/or damage
With Manual Locking Hubs
(see Figures 2 through 17)
  1. Raise the vehicle and install jackstands.
  2. Remove the wheel and tire assembly.
  3. Remove the retainer washers from the lug nut studs and remove the manual locking hub assembly from the spindle.
  4. Remove the snapring and spacer from the end of the spindle shaft.
  5. Remove the outer wheel bearing locknut from the spindle using 4 prong spindle nut spanner wrench, T86T-1197-A or equivalent. Make sure the tabs on the tool engage the slots in the locknut.
  6. Remove the locknut washer from the spindle.
  7. Remove the inner wheel bearing locknut from the spindle using 4 prong spindle nut spanner wrench, T86T-1197-A or equivalent. Make sure the tabs on the tool engage the slots in the locknut.
  8. Remove the outer bearing cone and roller assembly from the hub. Remove the hub and rotor from the spindle.
  9. Using seal removal tool 1175-AC or equivalent remove and discard the grease seal. Remove the inner bearing cone and roller assembly from the hub.
  10. Clean the inner and outer bearing assemblies in solvent. Inspect the bearings and the cones for wear and damage. Replace defective parts, as required.
  11. If the cups are worn or damaged, remove them with front hub remover tool T81P-1104-C and tool T77F-1102-A or equivalent.
  12. Wipe the old grease from the spindle. Check the spindle for excessive wear or damage. Replace defective parts, as required.
Fig. 2: Before beginning the wheel bearing removal, and after the outer hub is removed, wipe off any excess grease
Fig. 3: After the grease is wiped off, remove the axle shaft snapring ...
Fig. 4: ... then pull the splined spacer from the axle shaft end
Fig. 5: Use a 4 pronged socket to loosen the outer wheel bearing locknut ...
Fig. 6: ... then remove the outer locknut
Fig. 7: Remove the lockwasher from behind the outer locknut ...
Fig. 8: ... then loosen and remove the inner locknut-note the lockwasher engagement pin (arrow)
Fig. 9: While pushing inwards on the rotor/hub assembly, remove the outer wheel bearing ...
Fig. 10: ... then pull the rotor/hub assembly from the spindle, taking care not to scratch the bearing cups in the hub
Fig. 11: Pry out the grease seal on the back of the rotor/hub assembly ...
Fig. 12: ... then remove the inner wheel bearing. Thoroughly clean and inspect all of the parts for wear or damage
continue...
Jul 29, 2011 | 1989 Ford Ranger
How do I change the front wheel bearing in a 2001 Sonata 6 cyl
jack the front off the ground remove the tire remove the brake caliper remove the rotor remove the bolt hol;ding the front axle into the spindle hub, remove the hub and bearing.
May 06, 2010 | 2001 Hyundai Sonata
How to remove a rear hub assembly bearing on a 99 honda accord 4 cly 2.3.
The rear wheel bearing and hub unit are replaced as a unit.
  1. With the vehicle on the ground, loosen the spindle nut.
  2. Raise the vehicle and support it safely.
  3. Remove the rear wheels.
  4. Remove the brake disc retaining screws.
  5. Unbolt the brake hose brackets from the knuckle.
  6. Remove the caliper bracket mounting bolts and hang the caliper out of the way with a piece of wire.
  7. Remove the brake disc. If the disc is frozen on the hub, screw two 8 x 1.25mm bolts evenly into the disc to push it away from the hub.
  8. Remove the spindle nut and pull the hub unit off of the spindle.
Clean the backing plate and the mating surfaces of the brake disc and hub with brake cleaner. Clean the spindle, washer, and hub with solvent.
To install:
  1. Inspect the hub unit for signs of damage or wear. If the bearings are worn, the entire unit must be replaced.
  2. Install the hub unit and spindle washer onto the spindle. Install the spindle nut but do not tighten it.
  3. Install the brake disc and tighten the retaining screws to 7 ft. lbs. (10 Nm).
  4. Install the brake caliper and tighten the mounting bolts to 28 ft. lbs. (39 Nm). Install the brake hose brackets onto the knuckle and tighten the bolts to 16 ft. lbs. (22 Nm).
  5. Install the rear wheels and lower the vehicle.
  6. With the vehicle on the ground, tighten the new spindle nut to 181 ft. lbs. (245 Nm), then stake the nut with a punch.
  7. Tighten the wheel nuts to 80 ft. lbs. (108 Nm).
  8. Test the operation of the brakes.
ADJUSTMENT
The wheel bearings are not adjustable or repairable and should be replaced if found defective.
Thanks for using FixYa!!
Apr 20, 2010 | Honda Accord Cars & Trucks
How to change wheel bearings on a 96 cavalier
The wheel bearings on your car is contained in a sealed wheel hub. You have to change the whole hub to change the bearing. Remove the wheel, the brake caliper, the rotor. There will be three bolts holding the hub on from the back. You will need to remove these bolts and slide the hub off of the spindle. then grease the spindle slide on your new hub and bolt everything back together.
Sep 27, 2009 | 1996 Chevrolet Cavalier
How do i change wheel speed sensor on a 2001 pontiac grand am se
well if it is the front wheel speed sensor it is part of the hub bearing and that hub unit will have to be replaced as one unit.
first raise the vechile and support it with jack stands. remove the wheel that has the bad wheel speed sensor.
then remove the brake caliper and mounting bracket.
remove the brake rotor.
remove the axle nut from axle.
unplug wheel speed sensor wire harness and bracket.
un bolt the three 15mm bolts on the back side of the spindle for the hub bearing unit mounting.
after everything is un bolted you will need to soak the mating surface of the hub to spindle with wd-40.
take a hammer and cold chisel between the mating surface of hub and spindle. work your self around the mating surface of the hub.
depending how corroded it is the sensor part of the hub unit may stay stuck in the spindle and if that happens use hammer and chisel to remove it.
clean the inner surface of the spindle where the hub sits and re install in the reverse procedure.
if you have any more question please ask i will be glad to help. good luck
Sep 23, 2009 | 2001 Pontiac Grand Am SE
How to change the front wheel hub for 2000 LINCOLN LS
the whole spindle needs to come off unless you have the correct pullers here is a diagram have a good day DB
101414664
Feb 15, 2009 | 2001 Honda Civic
2006 Saturn Vue Wheel Bearing
it should come out once you have disconnected:Brakes,strut,ball joint.tire rod end,cv joint!if it is not put the cv joint nut back on until safe enough to give it a tap with hammer to knock back & out shaft this should come as one piece HUB the bearing is pressed in! better to change whole HUB good luck this hopefully helped you out!
Jan 31, 2009 | 2006 Saturn Vue
Replacing front wheel bearing
The brake rotor needs to be removed, drive shaft nut in center of hub then 3 bolts hold the hub assembly to spindle from back side. if it has abs unplug it then some work will need to be done with a hammer and chisel to work the bearing out of spindle and axle shaft from bearing
Oct 16, 2008 | 2001 Buick LeSabre
Change front wheel bearing 2001 ford escape.
you need to remove the spindle assy from the truck & press the bearing out & in   or you need to use a tool called the hub tammer to remove & install the hub bearing
Jun 28, 2008 | 2001 Ford Escape
Cannondale Jekyll 1000 Logo
146 people viewed this question
Top Cannondale Cycling Experts
Charles T Nevin
Charles T Nevin
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
