Question about Toshiba Portege R100 Tablet PC
Toshiba without battery
I have a toshiba r100 and a 2000. Both have power cords but batteries are dead.
1. Can I recharge these batteries?
2. Can just use the power cords to run the computer? How?
3. Can I substitute a 3v 25mAh for the 3v 17mAh cmos battery?
    Scholar:
  • 97 Answers
1. If the batteries are dead then there's no way that you can charge them again. You're better off purchasing a new one. You can purchase one online by visiting the ToshibaDirect website or by calling them on 1-800-316-09202.
2. Yes, you can use the power cords to run the computer. Just plug them in using the power cords even with the batteries removed and it should work fine.
3. Yes you can but you might experience some current fluctuations. This is negligible on a CMOS battery though.
Posted on Sep 18, 2008
How do I see if the recharger cord is working? Kindle fire did not recharge overnight.
Three possibilities. 1. Battery is defective. 2. Charger is faulty. 3. Tablet's 5V socket is broken or loose.
Jan 21, 2015 | Tablets & eReaders
IPad 2 not taking a battery charge
Three possibilities:
1. Worn out battery (rechargeable batteries have limited life span, then need to be replaced)
2. Bad charger
3. Bad cord
All three of these can be purchased and replaced.
Feb 18, 2014 | Apple iPad 2 Wifi 16GB
I have a toshiba tecra m4-s435. i plug it in to try to use it and the charging light just blinks i got a 12311 error code off it but i cant find the code anywhere to help me with this problem. i asked...
Error codes are only of use by the Toshiba Technical staff and of no use to you as the consumer.
If you report that to the Toshiba Technical personnel, they can transcribe the error number for you.
If a blinking light comes on when charging, sometimes it indicates No Charge or the power cell inside the computer is not accepting a charge and will not function. You might replace the power battery if it has been in there for several years. They do tend to die after a while. As for the computer, it should operated without the battery. If it fails to boot when the power adapter is plugged in, then one of two issues are common. 1, the power adapter is faulty and needs replacement. 2. the computers CPU may be damaged by a power surge and that is bad news.
Jan 11, 2018 | Toshiba Tecra M4-S435 Tablet PC
Nextbook2 will not turn on with a full battery
1) Try to plug the AC power adapter and see if the Nextbook2 turns on - if it does, there is 99% chance that the battery is dead. You can get the replacement battery only from the Nextbook manufacturer/dealer, nobody else sells separate batteries yet, not even on eBay.
2) If the Nexbook2 DOESN'T turn on even with the AC power adapter plugged in - see whether it (1) starts to load the system or (2) merely makes a sound, but nothing appears on the screen, or (3) maybe it doesn't even make a sound. In the (1) case you could reinstall the system, but it's not that easy without a built-in CD-ROM, so I recommend to bring it to the mechanic/dealer/manufacturer. There is no better solution possible.
Dec 25, 2010 | Tablets & eReaders
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
THE TABLET BATTERY DRAINED DEAD NOW IT WONT POWER UP WITH THE CORD OR BATTERY DEAD. IS IT THE BATTERY OR CORD THE PROBLEM. MY OTHER LAPTPS WILL STILL POWER UP IF THE BAT IS DEAD, IS THIS NOT TRUE FOR THE...
Have the power adaptor checked by an electrician, most probably you will need a replacement.
If you establish that the adaptor is working, then something happened to the battery charging circuitry in your Asus and it will need repair.
If it's still under warranty, then you are good, otherwise it would be better if the adaptor alone failed, as replacement adaptors are rather inexpensive compared to laptop repairs.
Dec 31, 2009 | ASUS R1E-B1 Tablet PC
Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Sep 03, 2009 | Gateway m1300-3004372 Tablet PC
My notebook will not charge. It stays on battery
pull the battery out and unplug the power changer hold the enter key for one full minute then install battery see what charge amount says if half way drain it till compter shuts off then charge, if it does not fix the problem the battery is dead.Rate if this was helpful.
Aug 14, 2009 | Compaq 2710p Tablet PC - Intel Centrino...
My Battery is not working!!!!!!!!!!!!!
Discharging the battery will not harm the battery. Lenovo purposely has an annoyingly slow recharge rate because a quick recharge will shorten the life of the battery. It is not a problem if you have the patience to allow a long recharge. Otherwise spring for a second battery for quick replacement when AC power is not accessible.
May 05, 2008 | IBM ThinkPad X60 Tablet PC
Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
Feb 08, 2007 | Acer TravelMate C112TCi-SP2 Tablet PC
Toshiba Portege R100 Tablet PC Logo
170 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
