Does the Conia HDTV ready LCD, Model CLCD 3270 ready for digital TV, if so how do I change it from analogue to digital as we cannot get digital reception?
  • 8 Answers
SOURCE: LG LCD HDTV 'NO SIGNAL'
if it still under warranty get intouch with LG-if not looks like (if its definitely not your input signal) theres a problem on the mainboard- if theres a firmware fix for the issue youll have to look into as there are many forums with ppl who have problems like this
Posted on Dec 18, 2007
djchillsnyc
  • 152 Answers
SOURCE: Is the Sanyo LCD HDTV Model DP 42647 a 1080P tv or not?
hello,
this tv is 720p heres a link to your manual info
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42647.html
hope this helps
Posted on Jan 09, 2009
  • 5346 Answers
SOURCE: can't get all digital channels
There are several possibilities assuming you have an outdoor antenna with the amplification. You are too far from the transmitter or the station is still on a low power digital transmitter until the analog broadcasts end. Additionally, there may be buildings, hills or trees in the way. The first one is called the digital cliff - you either have enough signal for your tuner or you don't. Some stations may need to add transmitters to cover the secondary areas that could still receive the analog signal. The second possibility will either resolve on Feb 18 or June 12 or anywhere in between. (It will depend on your station and the Digital TV transistion delay bill. Some stations are changing frequencies with the transistion and can't go to full power until another analog station moves its frequency.) The last one can't be resolved.
If you have an indoor antenna, you can try moving it around to get better results. My household has an amplified outdoor antenna with a rotator to get the antenna to line up with the signal. We have two analog stations that give problems when we look for their digital signals. We hope the issue will resolve with the changeover since we have seen the signals on both stations improve when they wanted to broadcast football games.
Posted on Feb 07, 2009
  • 4234 Answers
SOURCE: Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Posted on Jun 18, 2009
  • 8457 Answers
SOURCE: analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Posted on Jan 16, 2010
Do i need a digital set top box for conia cpdp4290 2007 model in australia
possibly yes but check what your input is set on to get antenna signal it can not be set on cable either AIR or antenna.
Jun 17, 2015 | Televison & Video
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 14, 2008 | Televison & Video
IS THIS A DIGITAL TV
The receivers of many older HDTV READY TVs had two receivers one for analogue and one for digital so that they could accommodate the new Digital signals as they were being broad cast by some stations only a few hours a day until the FCC made up it's mind to switch all stations to digital Since there are no more over the air digital signals, then if you can receive over the air stations with out having to run them through a converter, then you have an HDTV. cable companies send out a converted digital signal for it's older tv owners and a HDTV digital signal for it's HDTV owners, of which they charge a slight premium.
Jan 29, 2011 | Hitachi 57F510 57" Rear Projection...
HOW DO I CONNECT A VCR AND WHAT DO i SET THE INPUT ON.
If you have connected using the coax (aerial) ten the problem will be that the vcr is analogue and the tv is digital(if you have an older digital tv it should have an analogue tuner so you can set it to analogue and tune to the vcr) I suggest using a scart cable from the vcr to the tv, then you just press av on the remote(on some you can just change the channel down from 1 to the av inputs).
Jan 02, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
How can I get an analogue signal on my LG3000 32in LCD tv? Digital input is fantastic, but no idea how to obtain analogue. Input is connected to a community arial and other residents get analogue with no...
According to the manual I looked at, this TV has only one antenna input. This means that analog is available if you let the TV do a full autoprogram of memory. It might take it several minutes to complete, but once its done you should have analog and digital if available. If you were looking for analog channel 5 then you would just enter 5-0 but digital channel 5 would be 5-1.
Nov 12, 2009 | LG 32LG30 32 in. LCD HDTV
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
HDMI Input only reads Digital TV and not PS3 or AV Receiver
Well, I won't take the credit of others. Many people have the same problem as you do.
In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
Good Luck
Feb 16, 2009 | Philips 52 In. LCD HDTV
Conia tv remote codes
I have a Conia LCD TV and the remote died, I purchsed a universal remote and without the codes even on search modes could not get it to find the t.v. I found theat DJ Electronics sell replacement Conia TV remotes online. So if you just need areplcement remote, know your TV model number and you can just replce your old remote.
Jan 21, 2008 | Televison & Video
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
