Question about Husqvarna 24HP 54" Yard Tractor ()
Hello, my LGTH2454 has been running fine. It sat for about an hour then I went to start it and the starter engaged on the flywheel but won't turn. I took the starter off and tested it. It seems to work fine when off the tractor but when I reinstalled the starter it still wont turn the engine. The engine turns when I put a socket on the pulley. Is it possible for the starter to be too week to turn the engine but still work when on the bench?
  • 40 Answers
Sounds to me like the battery hasn't enough charge to turn the engine. Taking the starter off and testing it doesn't require much power as it doesn't have to turn the engine. Check the battery and also that the charging system is charging the battery back up. Alex.
Posted on May 20, 2011
Engine won't turnover
It sound like the starter solenoid that forces the starter gear onto the flywheel, you need to replace the solenoid unit.
Mar 30, 2013 | Rear Right Window Regulator & Motor for...
Starter doesn't engage the flywheel
Well since you replaced the starter, I think I would load test the battery cold and then again hot. It could be you have a dead cell in the battery and it is not producing enough voltage to work the starter solenoid.
Or it could be a bad connection between the battery and starter, or battery and ground.
Feb 13, 2013 | Ford Cars & Trucks
1965 mustang starter fires but won't engage flywheel. it is a brand new starter
Doesn't matter. The forks inside the starter may be missing or broke off or bad spring in starter that pushes the gear out. Try new started. Starter may have to be shimmed to make contact with flywheel. Starter may be kicking out but not engaging flywheel.
Jan 17, 2013 | 1965 Ford Mustang
Starter won't engage
check your flywheel & starter, one or both will be missing teeth, or the starter isn't "throwing out" yo engage flywheel
Aug 20, 2012 | 1989 Dodge Ram D-Series Pickups
2003 Lincoln Navigator starter grinding when starting
If you mean the starter grinds from time to time and won't crank the engine when it happens, the problem could be a bad spot on the flywheel and/or a faulty starter. The starter uses a magnet and bendix gear to push the starter gear into the flywheel. If the magnet or bendix is weak, the gear will not engage and can damage the teeth on the flywheel.
You need to have the starter removed and check the flywheel teeth for damage.
Aug 03, 2012 | 2003 Lincoln Navigator
1984 Ford Ranger Starter replaced but won't engage flywheel
it sounds like it need a shim to mount it up. not sure where you can get one though. maybe make it. search starter shims to see what i mean
Nov 30, 2017 | 1984 Ford Ranger
Starter works fine but won't crank engine. the pick up has to be given a push first before it starts
If the starter is spinning when you try to start but doesn't spin the engine over then you most likely have teeth missing off the flywheel ring gear. The facts that you say you have to push it and then it starts means the flywheel position changes and the starter has good teeth on the flywheel to engage. To confirm this next time the engine won't crank over remove the starter and look inside at the flywheel for missing flywheel teeth.
Mar 13, 2012 | Ford Cars & Trucks
Won't start been having trouble starting it a griding noise now won't start at all
Sounds like the starter on your car went out, when it makes a grinding noise ,
it's because the bendix or gear that engages the flywheel is worn , and is not
catching or meshing against the flywheel to turn it. if you are mechanicaly
inclined pull the starter off, take it to an auto parts store, most autoparts stores
have equipment to test the device at no charge, they can put a load on it and
tell you if its bad. just make sure to disconnect one side of the battery when
working on anything electrical. good luck!
Jun 25, 2011 | 2005 Kia Sorento
Husqvarna 24HP 54" Yard Tractor () Logo
296 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
