I have a gigabyte g41 and i can't hear of my headphone of front panel of my computer
    Guru:
  • 485 Answers
There are two things you want to check. Make sure the motherboard drivers are up to date. You can find drivers at the following link,
Click here for drivers
Also, you want to make sure the front panel wiring is correct and plugged in firmly. You will need to reopen the computer case and check this. Reference your motherboard manual for wiring confirmation. If you don't have this you can find it at the link above.
Regards,
G33k
Posted on May 20, 2011
How do I remove the front panel on a gigabyte case to install a new case fan
Look on the inside of the case behind the front panel to determine how the front panel is secured to the case.
Depending upon the type of case, remove the side panels or the desktop cover.
Front panels on desktop cases are secured to the case by either screws behind the front panel on the inside of the case, or by plastic locking tabs that needs pushing to unlock fron the case or if the front panel has an opening at the bottom then it may be held in place by friction lugs, in this case pull the bottom of the front panel and it will come away from the case.
Apr 29, 2012 | Gigabyte Computers & Internet
My gigabyte g41 combo doesn't detect front port jack . So i'm having problem in using headphones from when i bought this mother board.I tried both XP & 7 .My front port sounds only when i...
1. check if your front panel is connected to your motherboard at proper port2. check "expert mode" on your via hd audio deck, click "advanced options" and check "redirected headphone" (THIS WILL UNCHECK "INDEPENDENT HEADPHONE") and uncheck "enable front panel jack detection"
this should solve your problem.
Sep 22, 2011 | Gigabyte GA-G41M-Combo Motherboard
No sound in front panel and even pop message not coming on pluging in headphone in front panel of newly installed mother board
The front panel audio jacks are not connected to the motherboard. Take the computer to the service who installed new motherboard and tell them your problem!
May 16, 2011 | Gigabyte GA-P55-UD3L Socket 1156/ Intel...
My headphone jack on a HP computer is not working
first configure the front panel sound in control panel (start-> control panel )
even u have the same problem after configure the front panel,then check the wire connection of front panel.
thank u sir... Have a nice day
Apr 17, 2010 | Computers & Internet
Can't hear audio
I found many references to this issue but I am not sure which may apply to your problem. Here is a set of steps to follow from another site: (Assumes Vista and Realtek)
  • Open Vista’s Control Panel (Window | Control Panel)
  • Open the Realtek Audio Manager (not “Sound”)
  • In the navigation bar in the far right, there is a little yellow folder icon. It is just below “Device advanced settings” and above “ANALOG”. Click the folder icon.
  • Click “Disable front panel jack detection” so that a yellow check mark shows up. Hit “OK”, and close the Realtek HD Audio Manager. That should re-enable the sound
Mar 30, 2009 | Microsoft Windows? Vista Home Premium...
Dear sir, 2 years before i had purchased lg
download manual and refer it....all motherboard r same setting of front panel...
download manaul from below link
http://www.gigabyte.com.tw/Support/Motherboard/Manual_DownloadFile.aspx?FileType=Manual&FileID=17189
thanks
pls dont forget to rate me
bye
Mar 05, 2009 | Computers & Internet
I have a Dell Inspiron 1525 without the webcam .. when I use my headphone jacks in the front of my laptop I'm able to hear but the they can't hear me through my headset microphone. They're only able to...
Be sure that your headphone mic plug jack is plugged in to the mic jack (right-most jack) and not the second headphone jack. If so, check your sound setting in Control Panel and make sure the mic is enabled and the volume slider for it is up.
Dec 07, 2008 | Computers & Internet
No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Mar 14, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
